Batteries
Old Sep 2, 2012 | 07:55 PM
69cj's Avatar
69cj
Basically their all salesmen. The Walmart, autozone, Interstate, Optima, Sears and many others are all built by Johnson Controls. Look at the warranty and price and make your own decision.
Old Sep 2, 2012 | 08:14 PM
Yahiko's Avatar
Yahiko
At this point I want to know how each differs
and asking someone in sales is not going to give
a good clear answer. You don't get all the facts from
a webpage.
If fact it I went the way I really wanted to go I would get a set
wet cell Nicad. But then I would have to rework the charging
system and I really don't want to have to do that.
Sean
Old Sep 2, 2012 | 08:26 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I believe the general consensus is you should use a starting battery to start the engine, and deep cell batteries to run accessories.
Josh
Old Sep 2, 2012 | 09:31 PM
Fal-308-Win's Avatar
Fal-308-Win
I've used Die Hards all my life, never replaced one. Only way to get rid f them is to sell the vehicle
Old Sep 2, 2012 | 11:56 PM
Fulthrotl's Avatar
Fulthrotl
Originally Posted by Yahiko
I am not in need yet. Just doing some looking into.
Has anyone used the NorthStar Battery? (Made in the USA)
4 year full replacement
Batteries Plus has them under there own brand name
Group 65 AGM Marine X2Power Battery SLI65AGMDPM - Batteries Plus
NorthStar Group Size 65 AGM Battery - Remy Battery
VS.
Optima YellowTop (Made in Mexico)
Amazon.com: Optima YellowTop D34
Sean
Oddesy batteries are the best i've found.
i use this one:
Odyssey PC1750T
Old Sep 3, 2012 | 12:07 AM
Bullitt390's Avatar
Bullitt390
i use this one:
Odyssey PC1750T
Interesting... Odyssey = West Coast Battery, same as the OP's potential battery.
Josh
Old Sep 3, 2012 | 02:04 AM
Yahiko's Avatar
Yahiko
I was told that it the same engineers on both.
I just want to know now if they think it is a deep-cycle
or some type of hybrid battery.
I just discovered some thing. The URL that I was given is not
the right one
SLI65AGMDP Battery - 2003 to 2006 V8 6.0L Diesel 750CCA - F-350 Pickup - Ford - Car and Truck - Batteries Plus
Here is what is at the new link/URL It is not Marine
SLI65AGMDP Battery 2003 to 2006 V8 6.0L Diesel 750CCA F-350 Pickup Ford Car and Truck
2003 to 2006 V8 6.0L Diesel 750CCA F-350 Pickup Ford Car and Truck Battery SLI65AGMDP. Choose an X2Power battery made with pure lead technology to get Xtreme cranking and reserve power in a group 65 battery. The sealed AGM design means no acid leaks and improved safety. Made in the USA and backed by a limited 5-year replacement warranty.
Item number: SLI65AGMDP
Weight: 58.0000 lbs
Voltage: 12V
Capacity: 74AH
CCA: 930
Primary Applications: Police, Fleet vehicles, Automotive, Cars, Trucks, Off Road vehicles, classic cars and more
Replaces: NSBG650001
Sean
Old Sep 3, 2012 | 02:13 AM
Bullitt390's Avatar
Bullitt390
the right one
Weight: 58.0000 lbs
Voltage: 12V
Capacity: 74AH
CCA: 930
Sean
That's the equivalent battery I linked in Post #15.
I would personally stay away from a Marine or deep cycle battery for a diesel engine... UNLESS you are wanting to operate a bunch of accessories with the engine OFF. Like a stereo, lights, winch etc.
Even then I would question how well a deep cycle would crank over a cold diesel engine @ 0 degrees versus a regular starting battery, hybrid or not.
Josh
Old Sep 3, 2012 | 02:54 AM
Yahiko's Avatar
Yahiko
I just find it very interesting that the link was to the wrong
battery to start off with. I will still give then a call this week.
Then I'll post what I find out and any data I get.
Sean
Old Sep 3, 2012 | 03:09 AM
Nice Work Truck's Avatar
Nice Work Truck
Old Sep 3, 2012 | 04:36 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
all the brands are decent. just get the best price vs. the warranty. I'm rocking Interstates with 8yr warranty right now. Got them from Firestone. They had a $30 off coupon. Look around for the deals
most important though: the biggest/highest CCA!!!!! I don't care if it's a rinky dinky 1.8 4 banger, I still strive to get a minimum 800 CCA battery if it'll fit. Bigger is always better IMO for batteries. Especially a high compression PSD
Old Sep 3, 2012 | 07:54 AM
tr0y's Avatar
tr0y
Hey all - I'm going to jump in here, I live on batteries and deal with them often (off grid solar home). From a quick look at the specs those look like they will work well in a truck. I see people mentioning marine batteries, just because they are blue does not mean that, these appear to be AGM batteries. Absorbed Glass Mat batteries a different than your standard lead acid or gel battery as they are sealed and a glass mesh has been built into the battery. A good AGM will out perform a standard LA battery all day long. As for constant charging hurting them that is just false, also draining to 50% is false as well, they will deal with it, but they do not like to be drained that far, 75 to 80% is much more realistic.
What AGM batteries like is LOTS of amperage as they have very high interal charge rates, they also have the ability to push huge amperage as well.
AGM batteries are used in aircraft and in other very demanding situations such as dc to AC inverting that pulls huge amperage for sustained periods of time, or in long term floats where the batteries are charged constantly for a period of years.
With that being said, I still would stick with something like Costco / interstates due to the price point and warranty.
But if you have a spare 800.00 for batteries I say go for it.
T
Old Sep 3, 2012 | 08:31 AM
  #28
69cj's Avatar
69cj
AGM is the standard battery in HD motorcycles. 103 cubic inches being push by that small battery. And some of the bikes now have as many lights and acc. as a freightliner.
Old Sep 3, 2012 | 09:32 AM
  #29
Roasted7's Avatar
Roasted7
Being manufactured by one company in no way shape or form means they are the same battery. Johnson Controls build the batteries to the specs given them.
Just because Shasta and Coke are bottled on the exact same line doesn't mean they're the exact same product and quality.
Old Sep 5, 2012 | 01:12 PM
  #30
TDuncan's Avatar
TDuncan
Dont know if anyone is interested in these but I went to Truck Pro which is like Autozone for big trucks. they sell a battery called True Power
DB880-65
CCA 880
CA 1040 ( have no idea what this means )
RC 150 (reserve capacity )
They were $97.99 each out the door with one year free replacement. Has anyone ever tried these in a PU. I use them in my big trucks with no issue and they seem to last. Think the last one I replaced was 6 or 7 years ago
