A/C parts
Old Sep 1, 2012 | 11:16 PM
deere55's Avatar
deere55
A/C parts
Ok, what parts do I need to buy to have working A/C? I have a compressor, but I don't think I have anything else. I know for a fact that I don't have a condenser (was in front of the radiator right?), I took it out myself, and didn't bother putting it back because it was trashed. There's no lines as far as I can tell either. What else would I need to buy/see if I have in order to have A/C in this old truck?
Old Sep 2, 2012 | 09:18 PM
deere55's Avatar
deere55
A basic list with correct terminology would be fine. I'm not that familiar with air conditioning systems. Someone's got to know a little at least.
Old Sep 2, 2012 | 10:21 PM
vfelix702's Avatar
vfelix702
Your need compressor,line set to come off compressor, condensor,reciver dryer(accumlator), orrfice tube,134a,compressor oil
Old Sep 2, 2012 | 11:15 PM
deere55's Avatar
deere55
What do you do with compressor oil?
Old Sep 2, 2012 | 11:36 PM
vfelix702's Avatar
vfelix702
In any ac system ths oil is what lubes the internalz of the compressor... ex. 10 oz of pag oil and 3.25lbs of freon..... all go i the ac system...
Old Sep 3, 2012 | 11:00 AM
deere55's Avatar
deere55
I'm surprised it isn't mixed with the freon.
Old Sep 3, 2012 | 11:49 AM
vfelix702's Avatar
vfelix702
It does mix with freon... whe putting your oil in the system upon new ac in stall 5oz goes in the compressoer and 5 oz in the accumlator... then it mixes all around
Old Sep 3, 2012 | 05:43 PM
deere55's Avatar
deere55
So when searching for the orifice tube on oreilly's, I get a whole bunch of them priced from $2 to $50. Whats the difference?
http://www.oreillyauto.com/site/c/se...350&vi=1126606
Old Sep 4, 2012 | 12:01 PM
38Chevy454's Avatar
38Chevy454
Your best solution would be to find a junkyard truck and get all your parts for that. Except the drier/accumulator, get that new. Flush all the used lines, used condenser and evap and compressor on your truck to make sure they are clean. By getting all the parts off a junkyard truck, you will have all the right hoses and end fittings. You can buy new, but it will cost a lot. Put lube on any O-rings before installation. Use the right oil for your refrigerant (mineral oil for R-12, POE for R-134a). As Felix stated, the oil mixes with the refrigerant and is distributed through the system. Pull vacuum and make sure it holds. Put initial charge in and then start truck and add the rest using gages to tell when it is fully charged. The values for R-12 are not the same as R-134a.
If no vacuum, take the assembled and oil charged empty system to an A/C shop and have them vacuum and charge. It is critical to vacuum the system so no air and also to get rid of any moisture.
The expensive orifice tubes are variable. The std $2 one should be OK for you.
Old Sep 4, 2012 | 04:39 PM
deere55's Avatar
deere55
Thanks for the details. I may be in luck. Do you suppose the condenser/lines from a 93 E series will fit my truck?
I bought an old ambulance for an engine swap a couple years back, and I forgot that I saved most of that stuff.. I have a condenser and a couple lines, hopefully everything. The compressor that I have is the one that was on the ambulance engine and is still mounted under my hood. The condenser is a little bit messed up around the edges, but I don't know, maybe it is alright. They've also been sitting in kind of a dirty environment for over a year now...
How would I flush the system exactly.
I'm sorry I really know nothing about A/C, never touched any of it. I have a neighbor who comes over and recharges my systems for me. He said that A/c systems are too complicated to explain and it's easy to mess something up, then he showed me the 3 inch thick book titled "Air Conditioning" he has in his toolbox, and he said I'd be better off just letting him do it...
Old Sep 5, 2012 | 12:25 PM
38Chevy454's Avatar
38Chevy454
If the hoses and condenser fit you can use them. I do not know other than say try it and see. If no damage that makes a leak, it is OK. Flush by pouring solvent (mineral spirits is good) and then blow out with air. Do until clean and then final solvent rinse with lighter solvent (brake cleaner is good example). You want something that will not leave residue. Flush your evap and compressor also. Not just the hoses and condenser. Make the whole system clean, then connect it up using lube on connections as mentioned before. The lube is just a few drops of the same oil you put into the system.
A/C is not really that hard, but you do need to understand how the parts work and what is required. A few kind of specialized tools (vacuum pump, gages) and some knowledge. Certainly a home guy can do if you have the tools or understanding.
Old Sep 5, 2012 | 09:37 PM
greywynd's Avatar
greywynd
Anyone have any info or sources for a vacuum pump for this stuff? That's the one thing I haven't seen available here to be able to do my own AC work, or at least try to do it. Looking particularly for Canadian sources though, I know you guys in the states can likely get it at harbour freight or northern tool.
Old Sep 6, 2012 | 10:50 AM
deere55's Avatar
deere55
Thanks for the tips, and vfelix too.
bigTEE56
Sep 29, 2013 10:20 AM
sparrky81
Jun 20, 2011 07:32 PM
Help_Me!
Garage & Workshop
94
Aug 1, 2008 08:29 AM
daveengelson
Paint & Bodywork
Oct 14, 2007 09:52 AM
hotrod351
Feb 3, 2007 12:29 PM
