I have heard the sound before, and it is almost as though on a gasser you didn't have a plug in the hole, only quite muffled. More of a Thwahd Thwahd Thwahd.
Do u have AE? Can you check rotational velocities? I have 2 cylinders that can get above 6 (which I am told is bad) at idle when warm. Then we could tell if we have the same issue.
ok so here are some videos of my intake and exhaust sounds. You can hear it very well from the exhaust. I have never posted video so hope this works.
Your videos work fine. I know you said you replacing push rods(Personally I don't think you have a bent one). Also retorque and inspect the rocker arms/bolts, and injectors. Inspect the rockers closely as you might have one that is cracked.
Everything was done yesterday. Didn't fix it. Rotational velocities are still high on 3 cylinders
