Odd Cab rust
Old Aug 31, 2012 | 04:42 AM
fordman50's Avatar
fordman50
Odd Cab rust
What would cause the cab to rust like this about the drivers door? I see no holes in the roof. There is actually pin holes now above the wind shield too under the sun visor I know the body sat in a field for a year or 2
Old Aug 31, 2012 | 09:10 AM
mikeo0o0o0's Avatar
mikeo0o0o0
That would cause it.
When these trucks are built, all the metal is "spot" welded (AKA pinch weld). All the welding is done before any paint or primer is sprayed. Once welded together there is no way to get primer or paint in the tight joints between the metal BUT, moisture CAN and does get in to the bare metal. It starts as simple surface rust and over the 30+ years since it was built the surface rust turns into cancer and eats through the panels from the inside.
Sitting in a field compounds and speeds up the rusting. There is a lot of moisture coming out of the ground every day 24/7.
Old Aug 31, 2012 | 09:13 AM
fordman50's Avatar
fordman50
Hmmmm I have a spare cab that I am about to scrap... I think maybe I will cut it off the roof and save it in case I ever want a real resto fix.. I just filled it in with seem sealer and spray bombed it for now, it actually looks good LOL
Old Aug 31, 2012 | 10:38 AM
HIO Silver's Avatar
HIO Silver
What would cause the cab to rust like this about the drivers door? I see no holes in the roof. There is actually pin holes now above the wind shield too under the sun visor I know the body sat in a field for a year or 2.
I observed this phenomenon during my rig's make-over. It is caused by condensation forming on the underside of the roof... and if the rig is parked on tilt, the condensation will creep towards and collect on the low side against the roof seam(s) resulting in what you see there.
My rig was parked on the north side against the side of my garage... as the outside air warmed up, the interior of the truck did not since it was in the shade and experienced little if any interior air circulation... i literally watched the cardboard headliner slowly warp into deformity. I pulled it off one morning and saw that the entire underside of the roof was covered with huge droplets of water.
Think of a cold beverage on a warm day... condensation will form at the interface of a cold surface and warm air.
Old Aug 31, 2012 | 12:16 PM
jgavac's Avatar
jgavac
That's exactly the problem I have on the passenger side... I've been having a bit of a problem trying to find a local shop who can/will do that repair I even have a replacement
Jameson
Old Aug 31, 2012 | 04:06 PM
lafermedavid's Avatar
lafermedavid
same thing
thought about trying to weld with some filler,was told to use water proof bondo by one fellow tiger something.open to suggestions
Old Aug 31, 2012 | 06:53 PM
kevin316's Avatar
kevin316
The Tiger something would be Tiger Dylac (spelling?). They make a product by the name of Epo Strong. It is a filler that is made for use under powder coating. Its a lot like liquid steel but better. I used it on my frame before sending it in for powder coating.
Most powder shops won't have a clue what you are talking about but tell them to talk to their Tiger Rep. It comes from Germany and the instructions are all in German.
It works great and sticks good. It will even bend without cracking. I am going to use some on my inner fenders rather than bondo.
Old Aug 31, 2012 | 09:31 PM
mark a.'s Avatar
mark a.
I think there might have been sealer on top at one time that has gone away and let water in. Either way it's the kiss of death. You can fix it but it more than likely will be right back and there is probably damage done in the pinch weldes all down the rear piller and cab corner. By the time you'd fix all that you could have put a good southern cab on, nice ones without doors can be bought all day around my area for $300-$400 so it's not worth fixing as far as I'm concerened with no guarentee it just isn't going to come right back after doing all that work.
Old Aug 31, 2012 | 09:46 PM
HIO Silver's Avatar
HIO Silver
Ford applied a paltry amount of sealer in the rain gutter but roof rails are more likely to rust from the inside out as I described above.
Old Sep 1, 2012 | 05:34 PM
lafermedavid
tiger something
<TABLE border=0 cellSpacing=0 cellPadding=0 width=605><TBODY><TR><TD vAlign=top width=220 align=middle></TD><TD class=black9 vAlign=top width=560>Tiger Hair®
The original long fiber, fiberglass reinforced filler. Extra high strength and waterproof. Can be used with or without fiberglass cloth or mat. Blue cream hardener included.
<TABLE style="BORDER-BOTTOM: black 1px solid; BORDER-LEFT: black 1px solid; BORDER-COLLAPSE: collapse; BORDER-TOP: black 1px solid; BORDER-RIGHT: black 1px solid" id=tblProductInfo border=1 rules=all cellSpacing=0 borderColor=black cellPadding=3><TBODY><TR style="BACKGROUND-COLOR: #eeeeee"><TD class=bold8 align=middle>CATALOG NO.</TD><TD class=bold8 align=middle>SIZE</TD><TD class=bold8 align=middle>UNITS/CASE</TD><TD class=bold8 align=middle>WT./CASE</TD></TR><TR><TD class=black8 align=middle>1189</TD><TD class=black8 align=middle>Quart</TD><TD class=black8 align=middle>6</TD><TD class=black8 align=middle>20 lbs.</TD></TR><TR><TD class=black8 align=middle>1190</TD><TD class=black8 align=middle>Gallon</TD><TD class=black8 align=middle>4</TD><TD class=black8 align=middle>53 lbs.</TD></TR></TBODY></TABLE>
<TABLE style="BORDER-BOTTOM-STYLE: none; BORDER-RIGHT-STYLE: none; BORDER-COLLAPSE: collapse; BORDER-TOP-STYLE: none; HEIGHT: 20px; BORDER-LEFT-STYLE: none" id=prodLinks border=0 cellSpacing=0 cellPadding=5><TBODY><TR id=trMSDS><TD class=bold8 colSpan=3 align=middle><NOBR>MSDS <SELECT id=ddlMSDS class=black8 name=ddlMSDS> <OPTION selected value="100340 Cream Hardener.pdf">100340 Cream Hardener.pdf</OPTION> <OPTION value="101189 Tiger Hair 08-24-2011.pdf">101189 Tiger Hair 08-24-2011.pdf</OPTION></SELECT> View</NOBR></TD></TR></TBODY></TABLE>
my gutter has about a 2 inch seam spot on drivers side and 1 inch spot on passenger,again I thought about welding it,but someone told me to try the water proof sealers.Im familiar with tiger drylac powders,not in this area though,thankyou for the input,HIO what did you do to address your roof to rain gutter issue?</TD></TR></TBODY></TABLE>
Old Sep 1, 2012 | 05:57 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by lafermedavid
my gutter has about a 2 inch seam spot on drivers side and 1 inch spot on passenger,again I thought about welding it,but someone told me to try the water proof sealers.Im famaliar with tiger drylac powders,not it this area though,thank you for the input,HIO what did you do to address your roof to rain gutter issue?
My dentside's roof rails and gutters are okay at the moment. I stuffed insulation down the sides and lined it with an insulating pad... and I am currently don't have a headliner cuz it's all warped to hell.
It's my bumpside's roof rails and gutters that are corroded... I haven't done anything to them yet. It'll be a rat truck/test bed for now (to see if I can squeeze out 20 mpg out of an FE) but when the time comes I will likely replace the roof from the A-pillars up.
If your rain gutter's sealant is peeling or has gaps, dig it out and use 3M seam sealer. After application, it can be tool with your finger after it has been dipped in rubbing alcohol, lacquer thinner, or reducer. Let 'er set and it can be painted over.
66with352
Paint & Bodywork
May 25, 2018 09:59 PM
johnson.jeff.a
18
Aug 2, 2014 04:47 PM
SilverTrucker
Feb 4, 2013 11:19 PM
slojet
Feb 24, 2011 09:32 AM
nsaikia
Paint & Bodywork
Jun 8, 2005 09:16 AM
