aussie heads?
Old Aug 30, 2012 | 10:53 PM
udsuth78's Avatar
udsuth78
aussie heads?
found this site and was wondering if they where legit. $500 for a set of closed chamber head sounds reasonable. any help would be cool so???
http://www.ausfordparts.com/ausheads.html
Old Aug 31, 2012 | 07:34 AM
MBDiagMan's Avatar
MBDiagMan
Looks reasonable, but remember that these are bare heads. You will have lots of money in them once you add valves, springs, retainers and labor for the valve job.
Have you looked into the compression ratio with your pistons? What pistons are you using or planning on using?
Old Sep 1, 2012 | 06:35 PM
mark a.'s Avatar
mark a.
Yea, by the time you buy all the parts and get the machine work done you would be well on your way to having a nice set of aluminum heads. Why do you want all that compression in the first place ? With the price of fuel I always aim to have just enough compression for the job & no more. Then you can buy the more reasonably priced fuel. IMO for a street motor in a 4x4 9-9.5 is going to be plenty and pump friendly.
Old Sep 4, 2012 | 12:28 PM
MBDiagMan's Avatar
MBDiagMan
With aluminum heads you could get by with a little more compression due to their more rapid heat transfer properties.
Old Sep 9, 2012 | 08:04 AM
udsuth78's Avatar
udsuth78
yea tim meyer sells a set designed for the aussie head that makes 9.5:1
your right about the additional money it would take to finish these heads. its just that $2000 for aluminum is a tough pill to swollow.
Old Sep 13, 2012 | 09:25 PM
crsmiffy's Avatar
crsmiffy
just to make you sick-starting bids, but be surprised if it tops $1300
FORD 302 CLEVELAND CLOSED CHAMBER RECONDITIONED CYLINDER HEADS SUIT UNLEADED/LPG | eBay
freight ex Aussie not so helpful.
smallblock351w
Feb 28, 2007 06:44 PM
Young_unn
Sep 10, 2006 02:26 PM
Cybertaz126
Dec 4, 2005 05:26 PM
myred79
21
Jun 28, 2003 12:39 PM
phantom429
Jul 29, 2002 12:13 PM
