Shaving heads
Old Sep 10, 2006 | 09:48 AM
Young_unn's Avatar
Young_unn
Shaving heads
To increase compression can i shave a little bit off the bottom of the heads ans/or get thinner head gaskets, will it increase comepression, what else will increase compression? this is on any V8 engien, but im wondering about doing it to a late 70's 351(M,W,and C)
Old Sep 10, 2006 | 10:44 AM
airharley's Avatar
airharley
The best place to get that info would be in the engine forums. But I can say you for certain that shaving the heads will not give a lot of compression. The piston type determines that more then any thing. With a thinner head gasket, .042 compressed hieght, and milling the heads .020 will give at best .5 more compression. How much are you looking for?
Old Sep 10, 2006 | 02:26 PM
bob s jr's Avatar
bob s jr
be better using flat top or domed pistons with small chamber heads shaving the heads will give you a smaller chamber but doesnt make that much difference a 70 to 72 clevland 4 bbl was 10:1 comp 73 and later was 8:5:1 for feul and emission purposes also keep in mind to watch valve clearence when milling heads and chaning pistons but a good machine shop will help you with that 351m not a real good builder windsor is the easist and cheapest for parts and aftermarket availibility
dburgess
18
Dec 14, 2020 12:24 AM
ONTARIO4X4-6BANGER
Feb 23, 2010 04:37 PM
smoulding
20
Feb 4, 2006 12:57 AM
FordCardinal
Aug 5, 2004 05:42 PM
cecil
Feb 28, 2001 02:51 PM
