6.0 diesel
Old Aug 30, 2012 | 08:24 PM
king36's Avatar
king36
6.0 diesel
I was told 2 check my ficm and I did and it showing very low volts ...so I sent it off and had it repaired and had the upgrade also ... I installed and the truck ran so good for alittle bit and then start acting like it had no power at all ... So checked ficm again and was good.... Have no check engine lights on or nothin..... The truck will run good than start acting up and then run good again.... Any ideas on that..
Old Aug 30, 2012 | 08:26 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved to 6L forum
Old Aug 30, 2012 | 08:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
king, have the codes read anyway. The check engine light does NOT have to be on to see pending codes. Write 'em down and come back in here to list it/them. They are IMPORTANT!
Old Aug 30, 2012 | 10:15 PM
BLADE35's Avatar
BLADE35
do what Bud says^^^^
Then get you a scangaugeII and we can check the truckout
Old Aug 31, 2012 | 12:42 AM
Yahiko's Avatar
Yahiko
Ditto ^^^^^^
It could be so many things. It's
very hard to guess.
Sean
firefighter8124
Mar 4, 2015 07:47 PM
ncmountains
Jun 24, 2013 07:39 PM
bdostone
Sep 13, 2012 08:12 PM
CharlesCole
Jun 10, 2010 09:57 AM
powerstroke02
Dec 16, 2007 12:58 PM
