Sponsored by: Real Truck
Acetone
Old May 20, 2003 | 05:50 PM
Monsta's Avatar
Monsta
Sit. Stay.
Acetone
Originally posted by CBSuperduty
If you do take them off drop me an email and I will give you the link of where to buy new ones (can't or shouldn't post it on here as it is one of those "other" sites).
You can post the site! However, if the online store sells it just refer a user there.
If the store does not carry it, then let others know what site you are referring to. If it is a blocked site then a bunch of these #### will show up.
Old May 21, 2003 | 07:57 PM
usmccowboy's Avatar
usmccowboy
Acetone
i ordered the xlt stickers off of that site, but they are the ones for the f-150. they are not the same as the 250/350 ones. but ill give them a try and see how they look.
matt
Old May 21, 2003 | 09:18 PM
MarkF250's Avatar
MarkF250
Acetone
I sawed mine off with braided fishing line. It worked great! My XLT did come off. But I ordered new ones for it and it looks like the original. You can check out my pics on my gallery page.
Old May 21, 2003 | 09:38 PM
nafzimo's Avatar
nafzimo
Acetone
This thread talks all about the difference in letter size.
Matt
https://www.ford-trucks.com/forums/s...hreadid=105626
Old May 23, 2003 | 05:18 AM
99sdpstd's Avatar
99sdpstd
Acetone
I read an earlier post, ( a few months ago) a guy used 3 layers of 3" masking tape and on the last layer he added a trash bag under the emblems so all the gooooy stuff would go right into the trash bag.
Hope this helps.
I also heard not all emblems are doable. Any input on that????
My production date is 6/98.
Thanks
Old May 24, 2003 | 11:20 PM
cwb's Avatar
cwb
Acetone
My emblems came out great and they look so damn bitchin'. Thanks a lot, guys.
Old Jun 7, 2003 | 06:59 PM
6.0 F-350 Man's Avatar
6.0 F-350 Man
Acetone
My XLT sticker fell off help me out!!! email me at waterpologuy19(No Email Addresses In Posts!)
Old Jun 7, 2003 | 08:57 PM
RRMike's Avatar
RRMike
Acetone
Boy I don't get it. I tried to do mine and it was way too much of a pain I think. I had it all bagged up as this shows.
Well I started in with the brake cleaner with acetone in it and it started splashing around a bit and I think it was getting on the paint so I chickened out and fired up the hose and hosed the whole thing down.
The problem I was having is that the brake cleaner was evaporating so fast I had to keep hosing it down. Were you guys spraying it on or soaking something then rubbing? It sounds like I've heard both.
Anyway I think the emblems are coming off if I ever do this mod. I'm too chicken
Old Jun 7, 2003 | 09:08 PM
RRMike's Avatar
RRMike
Acetone
Well I guess my gallery isn't working. I had a trash bag over it with it cut out from the inside around the emblem.
Old Jun 7, 2003 | 11:42 PM
cwb's Avatar
cwb
Acetone
Q-tips and cotton ***** for me.
Old Jun 7, 2003 | 11:50 PM
RRMike's Avatar
RRMike
Acetone
What did you use? Brake cleaner? I tried wiping it some but got scared that I was going to screw it up and not wanting to have 1 emblem with the paint gone I stopped.
You masked around it and then just kept wiping at it until you got it all off? It seems like there are spots you couldn't even get with q-tips.
Old Jun 7, 2003 | 11:58 PM
cwb's Avatar
cwb
Acetone
I used straight scetone from Home despot. I made sure that there was enough acetone in the ball to run into the crevice but not out and down the side. You kind of have to pinch the ends of the q-tip to reach some of the tight spots.If you rinse the tighty's in that way a few times they come clean.I taped the s*** out of the bottom and around the sides , too cause I was so chicken of getting it on the ppaint. By the second one I was a pro.
Old Jun 8, 2003 | 05:21 AM
  #28
Autobahn F-250 Lariat's Avatar
Acetone
I used acetone as well and applied it with a toothbrush it worked really well. I taped the heck out of it and used a 3mil plastic to drape on the remainder of the paint below the emblem. I have pics of the tape job in my gallery as well as the finish product.
Manny
Old Jun 8, 2003 | 10:54 AM
  #29
RRMike's Avatar
RRMike
Acetone
Yeah that still scares me too much. I think I'm gonna take the emblems off. I've seen where a heat gun and some fishing line will take them off. The question is does the double sided tape stay on the truck and you re-use it or do you have to put new on? I think I might just go buy new emblems from a junkyard and do them. Then just put them on the truck.
It just seems like the acetone could soak through the masking tape. Is that stuff water(Acetone)proof? If so maybe I'll try again.
Old Jun 8, 2003 | 04:46 PM
  #30
cwb's Avatar
cwb
Acetone
I used blue painters tape which will withstand acetone but I also used about three layers. You can also use green painters laquer tapre which will work about the same.
