Changing gear ratio
Old Aug 28, 2012 | 11:10 PM
FordYoungGun35's Avatar
FordYoungGun35
Changing gear ratio
96,f150 5.0 4x4.. How hard would it be to change to a 4:10 I'm pretty sure mines the 3:55
Old Aug 29, 2012 | 01:42 AM
GNR22's Avatar
GNR22
2 routes you can go, change the whole axle out for one with the ratio you want, or have the ring and pinion swapped. You might also need to have the carrier changed between those 2 ratios. I don't remember if the carrier is the same with both those ratios. But having the ratio changed in your axle requires someone with experience in doing so since it has to be shimmed and aligned correctly. If you swap the axle, you can do that by yourself with basic tools. You just unbolt the driveshaft, remove the ubolts, remove the shocks and brake lines, and probably some sensors and junk, and swap in the new one and good to go.
Old Aug 29, 2012 | 06:58 AM
burnout400m's Avatar
burnout400m
^ don't forget the front! The front has a removable center of 3rd member. You can order one already set up and swap them yourself. I don't know if Ford ever offered the 8.8" with 4:10 gears but if they did then swaping the whole rear end would be the easiest route.
Old Aug 29, 2012 | 07:09 AM
garthneddy's Avatar
garthneddy
If your asking how hard it would be to set up gears, have a shop do it for you.
Old Aug 29, 2012 | 07:22 AM
FordYoungGun35
Yah I just wanted to know if I need to just buy a ring and pinion set or what?
Old Aug 29, 2012 | 07:27 AM
garthneddy's Avatar
garthneddy
You will ned the gears, bearings, seals and shims
Old Aug 29, 2012 | 09:53 AM
FordYoungGun35
so say i get all of this stuff threw summit will someone give me a shopping list
khardrunner14
Jan 27, 2010 07:24 PM
cjben
Mar 9, 2008 01:25 PM
broesky
Jan 26, 2006 08:26 PM
savage066
May 19, 2005 10:29 PM
76 4x4 460
Jul 17, 2003 10:52 PM
