gear swap
Old Jan 26, 2006 | 05:37 PM
broesky's Avatar
broesky
gear swap
is it possible to convert a solid front axle on a 1978 F-150 from 4.10 gear ratio To 3.08. is there kits still available to do this conversion if it's even possible?
what do i all need to do this conversion
Old Jan 26, 2006 | 06:00 PM
76f150_4x4_360fe's Avatar
76f150_4x4_360fe
just a ring gear and pinion that fits your differential should do it
Old Jan 26, 2006 | 06:27 PM
76 F-150 390FE's Avatar
76 F-150 390FE
you also need a carrier. the high ratio carrier its 3.92+ and the low is 3.73 and down.
just wondering what condition is the carrier and the gears in? and what do you plan on doing with them?
Old Jan 26, 2006 | 07:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Remember to change the rear to match.
Old Jan 26, 2006 | 08:26 PM
broesky's Avatar
broesky
I got a 1994 F-150 4x4 truck with the TTB in front and i want to switch to solid axle. My back end has a 3.08 gear ratio,but back in 1978 they didn't have 3.08 diffs.
If i got to swicth the back end out to one that matches the front axle then i got to change the tranny over to so the truck will drive at a normal speed. Any suggestions would be apreciated.
Bigwrm
Apr 22, 2011 04:22 PM
darthice
Offroad & 4x4
Jan 28, 2010 11:42 PM
fyrtrks
Oct 16, 2005 07:47 PM
monsters
17
Apr 15, 2005 08:30 AM
