Sponsored by: Real Truck
2011 Wheel Compatibility
Old Aug 28, 2012 | 07:36 PM
iez44's Avatar
iez44
Which wheels from other years are compatible with the 2011?
Old Aug 28, 2012 | 07:54 PM
fordman19762003's Avatar
fordman19762003
I believe '04+ are compatable, or whenever Ford switched from leaf to coil springs on the front.
Old Aug 28, 2012 | 10:48 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
05+ Superduty
Josh
Old Aug 29, 2012 | 12:39 AM
Firekite's Avatar
Firekite
Depends on what you mean by "compatible" I guess, but for reasons unknown Ford switched from 8 on 6.5" to 8 on 170mm with the switch to the Super Duty lineup for model year 1999.
Old Aug 29, 2012 | 02:22 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
any 99-2013 17" or larer rim will fit
however only 05-13 rims will work properly. the 05+ axles are wider than 99-04 trucks. that means the backspacing on the 99-04 rims creates fitment problems for driving
also remember that your brake calipers require a 17" rim or larger. most 99-04 rims are 16"
Old Aug 29, 2012 | 01:26 PM
iez44's Avatar
iez44
thanks for all the info. i've seen ads for rims that state "will fit 2008-2010" or "only fits 2005-2007." i also couldn't find the wheel specs for 2011 for comparison, so i came to the place with all the answers!
thanks again!
HiZ
Jan 9, 2016 11:26 AM
ramchargerjay
May 3, 2014 05:07 PM
05blueEx
Sep 7, 2012 11:18 PM
madcatter33
Jan 19, 2010 11:07 AM
Turbo666
Nov 21, 2008 06:16 PM
