transfer case fluid change
Old Aug 28, 2012 | 05:31 PM
codybear's Avatar
codybear
Ok. I'm confused. I did a search here for the proper fluid to use in my transfer case, and I'm starting to get a headache. I have a 2002 F 250SD 4x4 with a 5.4 w/.automatic trans. My owners manual says 2 qts of Mercon ATF, but some of the posts I read say no. Is there a specific transfer case fluid I should be using? What brand? And friction modifier is only for rear axle?
Old Nov 26, 2012 | 05:00 AM
NodnarbDFD's Avatar
NodnarbDFD
lots of manual transmissions require Merc ATF and if it came with it and lasted 174k like in my 02 5.4 4r100 transfer case why not stick with it.
Old Nov 26, 2012 | 06:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Why not? Because MERCON has been discontinued and MERCON V has replaced it.
You can still find fluids that say they are for use where MERCON was specified, but do you know if those fluids still meet the MERCON specs? I don't.
Old Nov 26, 2012 | 01:49 PM
NodnarbDFD's Avatar
NodnarbDFD
The only difference in merc atf and mercv is that its rated for a higher temperatures and that it is more slippery. What wouldn't benefit from keeping temps lower and more slippery. I've used it for my t-case and haven't had a prob. If you want amsoil or syncromesh would be another alternative.
Old Nov 26, 2012 | 02:05 PM
NodnarbDFD's Avatar
NodnarbDFD
Also why did they really end merc atf? one of the stipulations in merc atf was shift feel in The Taurus transmission. What model ended in 2006? The ford Taurus. So how would you judge shift feel in a vehicle that no longer exists.
Make merc V and it doesn't have to be tested in a Taurus. Should ford waste money testing it in t cases? why not make a different fluid all together insert "motorcraft transfer case fluid"
Batgeek
Jun 13, 2019 11:06 PM
Dads79
2015 - 2020 F150
Feb 26, 2019 08:50 AM
parcours
Dec 22, 2016 10:03 AM
VQT
Apr 29, 2013 08:55 PM
perryphilip
Mar 2, 2002 06:42 PM
