Body Lifts
Old Aug 27, 2012 | 11:29 PM
jgavac's Avatar
jgavac
Body Lifts
Is there by chance any sort of a body lift that will work on a 2wd F250? All the ones I've been finding online say they won't work with trucks that have steering box close to the firewall, which is what all 2wd truck have (right?). The main reason I'm looking is so I can fit larger tires when it comes time to replace the ones I have (can't find any under 35" that fit a 16.5 wheel).
Thanks
Jameson
Old Aug 28, 2012 | 10:54 AM
montana_highboy's Avatar
montana_highboy
BFG makes a 33" tire in 16.5's....it's the All Terrain T/A KO
Old Aug 28, 2012 | 12:07 PM
keiths78f150's Avatar
keiths78f150
BFGoodrich*All-Terrain T/A KO
Super Swamper TSL Radial 32x12.00R-16.5LT
http://www.4wheelparts.com/prodDetai...artno=SSTS-204
Super Swamper TSL Radial 33x12.50R-16.5LT
http://www.4wheelparts.com/prodDetai...tno=SSTSAM-54R
The best choice would be the BFG All Terrain's.
Old Aug 28, 2012 | 01:10 PM
garthneddy's Avatar
garthneddy
I have also heard that body lifts will not work on these trucks. Have you thought about just doing a small suspension lift?
Old Aug 28, 2012 | 01:21 PM
JB78f150's Avatar
JB78f150
Maybe put in some new untired springs in the front?
Old Aug 28, 2012 | 03:57 PM
kobaltblue's Avatar
kobaltblue
A body lift will work on a 2x but it takes a little more work, Your going to need to drop the front of the steering column and change out the rag joint to a U joint type.
But dont go over a 2" lift
Old Aug 29, 2012 | 02:03 PM
jgavac's Avatar
jgavac
Springs were replaced by the p.o a few years back.
Ideally I'd go with a suspension lift. But the Autofab 3 inch econo lift is $800
What about making a bracket to move the box up 2 inches, then putting a spacer in between the pitman arm and the steering gear?
Thanks
Jameson
Konabro2
Jul 3, 2014 11:55 AM
79stepsideF150
May 9, 2013 11:32 AM
Myfreeford
Jun 4, 2012 04:04 AM
mustangsrmine
19
Feb 11, 2009 09:36 PM
offroad17
2004 - 2008 F150
13
Dec 2, 2008 09:10 AM
