Well found fuel leak.
Old Aug 27, 2012 | 08:39 PM
TAT2DUP81's Avatar
TAT2DUP81
So was looking at something under good then smelled fuel. Looked over and seen fuel dripping from fuel filter housing. Isn't have tools to mess around at it so have to wait till tomorrow Ben get to work. But is this a common leak area? Looked like line goin into house but not sure. Anyone else have this issue before.
Old Aug 27, 2012 | 08:48 PM
Fal-308-Win's Avatar
Fal-308-Win
Mine was leaking from the banjo cappie wappie' thing. Got a new one with the blue spring up grade. Now all gone
Old Aug 27, 2012 | 09:15 PM
TAT2DUP81's Avatar
TAT2DUP81
Just don't wanna wait to order new spring plus haven't check on availability or pricing on one
Old Aug 27, 2012 | 09:33 PM
Fal-308-Win
Blue spring comes with O rings for fuel line to regulator housing. Doubt that's where your leak is. There so tight some guys can't get them off some guys twist the line. Your talking about the line on driver's side pointing toward rear of truck? I understood that to be a fuel return line to tank? Could be wrong. But a pressurized leak would be spraying? Some one tell me if I'm right or wrong. And be nice
Old Aug 27, 2012 | 10:42 PM
jmaskew's Avatar
jmaskew
The rubber gasket (I was going to call it an "o-ring" but it isn't really a circle...lol) on the blue spring housing flattened out on mine and caused a leak. If yours is leaking in the same area then now is a good time to put the blue spring in. If you are lucky enough to have an International Dealer near you that will sell you the part I think you can pick up the blue spring kit for around $40. Mine wouldn't sell me the kit when he found out it was going in a Ford so I had to get one from the dealer for around $80 or so.
Old Aug 28, 2012 | 08:05 AM
florida_1959's Avatar
florida_1959
that "key hole" gasket behind the side plate on the filter housing is a good place to check, as they will leak. If you find it to be that gasket, it would be the time to make sure you have the blue spring installed, as it will potentially save your injectors from fuel starvation.
Old Aug 28, 2012 | 08:13 AM
TAT2DUP81's Avatar
TAT2DUP81
It's leaking on the right side of housing. I'd post pics but I use the mobile site from phone. I do have an international dealership here in KC. Anyone have part number and is there anything else I'll need to do repair?
Old Aug 28, 2012 | 08:48 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Blue Spring
Upgraded fuel pressure regulator kit (with cover): Ford#3C3Z-9T517-AG*IH #1843065C98
Fuel Pressure Regulator "Spring and Reseal Kit Only" (no cover, should be much cheaper, has gasket): Ford#6E7Z-9C165-B IH#1854267C94
Regulator cover gasket only: Ford#3C32-9C065-AA
Ther's a thread in the Tech folder if you want to see some pics.
https://www.ford-trucks.com/forums/1...ue-spring.html
Old Dec 6, 2012 | 11:29 AM
ash289's Avatar
ash289
I've had the fuel smell in the cab for two months and found the fuel drip off housing today.
The Tech folder thread is wonderful.
I'm going to do this when I replace the EGR & Oil cooler later this month.
Old Dec 6, 2012 | 07:59 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
How long since you changed that filter? Maybe the o-ring on the cap got pinched? Or a hairline crack in the cap?
blue spring:
Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit
Old Dec 7, 2012 | 10:09 AM
ash289's Avatar
ash289
Yep. Found leak. Yesterday. Already bought kit.
Thanks.
Furniture Doctor
Sep 8, 2018 11:04 AM
rkulp89
May 3, 2015 12:45 AM
Hotwheelbill
Mar 6, 2014 08:27 AM
davidlea
Dec 14, 2012 10:36 AM
natewood75
Aug 15, 2010 08:08 PM
