Fuel leak
Old Aug 15, 2010 | 07:12 PM
natewood75's Avatar
natewood75
Question Fuel leak
I have found the source of my fuel leak. when standing in front of my truck on the right hand side of the fuel filter housing there is a fuel line coming into the housing. you can remove this with a 20 torx bit and loosen the fuel line. the peace that is screwed onto the housing the threads are pulled and the leak is there. I removed that peace and there is a spring behind it. what is this part called and where can you get it. Thanks
Old Aug 15, 2010 | 07:24 PM
bobbyrjw's Avatar
bobbyrjw
You have found your fuel regulator.
Good time to put your FrX from RiffRaff on. Order a Ziggy installation kit (Ziggy is UPS'ed to you to be delivered with his tap and extra screws).
Bob (Robert6401) had this happen to his bowl when he was attempting to put on his FrX at the RRE. Ziggy had a tap and the right size screws to fix it.
Old Aug 15, 2010 | 07:56 PM
natewood75's Avatar
natewood75
the screws are fine but the housing that is screwed to the fuel housing is striped. the Peace that the fuel line attaches to. the fuel line is bolted to the housing for the fuel reg. thanks for your quick response
Old Aug 15, 2010 | 08:08 PM
natewood75's Avatar
natewood75
found it at riffraff
thanks man. 40 bucks and a couple of days i will be back on the road.
