P0745 code OD light flashes
Old Aug 27, 2012 | 07:45 PM
sgtscrounge's Avatar
sgtscrounge
I have a 2004 Aviator with a 5r55S transmission.
O/D light started flashing, difficult to shift gears, MIL came on with P0745 code
I have changed the filter, installed new solenoid block, adjusted bands, topped off fluid with Mercon V. No change in symptoms.
Any ideas ?
Old Aug 27, 2012 | 09:08 PM
shorod's Avatar
shorod
That code is defined as "PCA solenoid defective" and is slightly less generically defined in the service manual as meaning, "Mechanical failure of the solenoid detected." The troubleshooting steps start by suggesting you confirm first that the electrical connector is firmly seated. The next steps involve installing a pressure gauge to check for line pressures after commanding specific pressures using the scan tool, then doing further electrical checks using the scan tool and a multimeter.
Do you have access to a scan tool and pressure gauges and fittings that will allow you to perform the pressure checks? If so, and you would like a copy of the service manual for this section, send me a Private Message with the request and an e-mail address for you.
-Rod
brianvabeach
2004 - 2008 F150
Mar 1, 2011 06:20 PM
dsljay
Jun 15, 2009 11:25 PM
1red911
Jan 14, 2008 08:29 PM
larrym3
Dec 8, 2004 08:30 PM
