Part ID?
Old Aug 27, 2012 | 12:57 PM
TheWedge1's Avatar
TheWedge1
Part ID?
I have a 1973 F100 (302 / Automatic) I am working on rewiring, I removed the complete wiring harness due to the P.O. who ever so kindly melted it. I am replacing it with a complete harness out of a 1978 F100 but there is a plug that I cannot identify on the '73. It is on the steering column near the firewall inside the cab, it looks to be a spring loaded switch with 4 wires coming out of it to a 4 pin wire flat plug that looks identical to a trailer wiring plug. Any help with what this is because the harness from the '78 does not have anything to plug back into this? Thanks.
Old Aug 27, 2012 | 12:59 PM
keiths78f150's Avatar
keiths78f150
I wouldn't have a clue because I dont know hardly anything about wiring except how to hook up a sound system. What I do know is that pics will definitely make things easier for the guys who do know what they are talking about to identify.
Old Aug 27, 2012 | 01:09 PM
TheWedge1's Avatar
TheWedge1
I think I have figured it out. It seems to be the neutral safety switch, how would I go about splicing this into the '78 harness b/c I would assume the '78 had the switch on the transmission itself?
Old Aug 27, 2012 | 03:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You are correct, that's the NSS. The '78 harness should have a gray, square connector with four wires going to it, white w/ pink trace, black w/ red trace and two red w/ blue trace.
Old Aug 27, 2012 | 03:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/77 F100/350: The NSS is located on the steering column (C7TZ-7A247-A / Motorcraft SW-600). Same I-6 & V8.
1978/79 F100/350: The NSS is located on the trans. C6 (D8TZ-7A247-A / Motorcraft SW-1489) uses a different NSS than a C4 (D8TZ-7A247-B / Motorcraft SW-1491).
1978ShortboxF-150
Jan 8, 2016 02:05 PM
kaden78ford390
WTB - Parts & other
Nov 8, 2015 09:18 AM
Boss_358
May 24, 2010 03:32 PM
F250GH
Jan 25, 2009 09:08 PM
teds74ford
Electrical Systems/Wiring
Jan 2, 2005 10:34 AM
