need help
Old Aug 26, 2012 | 11:16 PM
Sara Boggs's Avatar
Sara Boggs
Unhappy need help
My '2000 Ford Explorer XLT will only shift into drive when it is started in neutral. Why is this and how can I fix this??? PLEASE HELP!!!!!! This is every time it is put into park you have to turn it off and turn back on while in neutral!
Old Aug 27, 2012 | 06:47 AM
shorod's Avatar
shorod
Since you don't mention any difficulty shifting to neutral from park, I don't think the issue is the brake interlock switch. It sounds like the most likely issue is related to the Park/Neutral Safety Switch, often called by Ford the Transmission Range Sensor or Digital Transmission Range Sensor. I suspect either the sensor is slightly out of sync so that it's not quite getting the proper signal when in Park but is close enough that Neutral still works, or the switch has failed and the contacts for Park are worn.
These can be pretty easy to test with a test light or multimeter and wiring diagram for the circuit.
-Rod
Old Aug 27, 2012 | 10:04 AM
Sara Boggs's Avatar
Sara Boggs
Unhappy
Actually when you start it while it is in park it will not shift into any gear! The only way it will shift is if you start it in neural!
Old Aug 27, 2012 | 10:22 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Just found this thread. That is weird as I never heard of this situation. If it starts in Park, it won't shift out, but if you start it in neutral, it will shift into different gears. Hopefully someone else will chime in on this.
Old Aug 27, 2012 | 01:04 PM
shorod's Avatar
shorod
Check to see if your brake lights work. There is a shift interlock solenoid that will prevent shifting from park unless your foot is on the brake pedal. It's apparently pretty common for the original brake pedal switch and connector to fail, so much so that they have redesigned the replacement switch and connector. Since if the vehicle stalls while driving they want the driver to have the ability to shift to neutral, restart, then shift back in to drive, the interlock does not apply to the neutral gear position.
If your brake lights are not working, chances are pretty good the brake pedal switch is the issue. I found a replacement with wiring harness pigtail at O'Reilly Auto Parts for less than $20 and it was in stock for my 2004 Aviator. That was quite a bit less expensive than some of the competing local stores wanted for the same switch and pigtail.
-Rod
Old Aug 27, 2012 | 06:44 PM
aquanaut20's Avatar
aquanaut20
ROD<
I may be mistaken, but as I understand her issue... The truck will start in P and she is able to move the shift lever, but the transmission will not actuate any gear.
If started in N the transmission will pressure up and drive.. Philip
Old Aug 27, 2012 | 09:20 PM
shorod's Avatar
shorod
I guess we're going to need some clarification from her.
-Rod
Old Aug 27, 2012 | 10:21 PM
steve(ill)'s Avatar
steve(ill)
If the truck starts in park, but when you put your foot on the brake and try to shift into gear and it wont go... im betting on the brake pedal switch also.
Old Aug 28, 2012 | 12:04 AM
SBV45's Avatar
SBV45
Sounds like it could be the brake-shift interlock. Depending on her model, the owner guide might show how to bypass that in emergency My owner guide describes how to do it on mine.
kevin-11
Apr 8, 2025 07:00 PM
little_scrapper
13
Aug 8, 2011 02:02 PM
69ford99
1978 - 1996 Big Bronco
Jul 23, 2006 02:12 PM
scotty8812
1997 - 2003 F150
Aug 13, 2005 04:44 PM
conoroneil
1997 - 2003 F150
Sep 5, 2003 08:23 AM
