gold coolant
Old Aug 28, 2012 | 08:31 AM
  #31
69cj's Avatar
69cj
Originally Posted by bismic
Looks like the same stuff that was in mine. Took less than 500 miles to plug the 1st filter. App. 1500 miles for the 2nd and shes been good since. It did cost Ford one set of coolers before the filters got it all out.
Old Aug 28, 2012 | 08:42 AM
  #32
dchamberlain's Avatar
dchamberlain
Originally Posted by vloney
Cross contamination of coolant types can and will produce "goo".
This is an interesting statement. I wonder how many clogged oil coolers were caused by someone adding over the counter generic "works in everything" coolant.
Do you know any specifics, like what crossed with what can cause a problem?
Old Sep 8, 2012 | 03:13 PM
  #33
BLADE35's Avatar
BLADE35
I have seen where the Will Fit Green coolants Cause a Slim layer when Folks run those type coolant
Volony statment is right on never thought of it that way but Makes perfict sense
Iv seen alot of folks post after getting work done at a shop and say the shop installed Green Coolant
Old Sep 8, 2012 | 03:15 PM
  #34
BLADE35's Avatar
BLADE35
That stuff looks about the same texture as what was in mine
Mine was More Silver looking
I havent found anymore since I Flushed cooling system and changed the Oil Cooler but have checked My Coolant filters all except 1 since and found nothing
Old Sep 8, 2012 | 09:45 PM
  #35
Fal-308-Win's Avatar
Fal-308-Win
Bismic the sample you got out or your coolant filter, is it heavy or light? Hold a magnet to the outside of the glass jar and see if its affected!
Old Sep 8, 2012 | 09:49 PM
  #36
bismic's Avatar
bismic
It was definitely not heavy, but it really wasn't light either. It was not magnetic. I had it analyzed and the most common component is silica. I got this material out of the coolant filter 5 1/2 years ago (not long after buying the trucks). Had kept some of it, but can't find it now!
I assume it was casting sand. I got it all out on the first coolant filter change. Never plugged up a filter after that.
Old Sep 8, 2012 | 09:57 PM
  #37
Fal-308-Win
Well that blows my theory, I live in Calif Gold Country and it looked like the black sand you get in the bottom of the pan during final wash out.
Old Sep 9, 2012 | 04:33 PM
  #38
04badford's Avatar
04badford
Hey guys would some of oil or even diesel treatment would play any roll like seafoam etc just wondering and I've had gold in my 6.0 still looks clean
Aune163rd
Jun 24, 2016 05:45 PM
Kdawg89
Jul 19, 2015 01:59 AM
bismic
Feb 15, 2011 10:12 PM
plgebbia
Aug 17, 2010 11:24 PM
lakewood
Apr 15, 2010 08:57 PM
