gold coolant
https://www.ford-trucks.com/forums/1...cs-inside.html
This may have caused an inability to effectively transfer heat. Perhaps this was caused by the presence of hard water in my system from the previous owner(s). I was expecting to see it clogged, but it just wasn't the case on my truck.
-Eric
Thermal forces and even chemical action can free it up.
International engines have had oil coolers plug up. I mean why would International install filters if they didn't see a need?
I think we know that there were head bolt torquing issues early on, so a poor cleaning process on many blocks is not that hard to accept.
Anyone agree^^ or NO???
So does that mean if Its (as in Oil Cooler) is clogged Bad enough that the Coolant flow (as in NO FLOW) in the EGR Cooler would almost be Sitting there (Very Little GPM) like getting Boiled in a Pan
So now where down to what DChamberline mentions Does anything Happen to the GOLD even if it does Boil????
Iv seen more Oil Coolers Clogged with Casting sand that Golden Goo and thats only a small amount of the Folks that have Cut them open on FTE and posted a Pic
So your saying the 2 things here Casting Sand Or Silicate can Look the Same????
I don't know that for sure, however. Because I haven't done it.
I would imagine that the coolant in an EGR cooler that has a significantly reduced flow could boil, and it could also after it boils get even hotter than that as steam. Then be cooled once it reaches the main flow of coolant again. The expansion that would occur should show up in the degas bottle possibly as puking, though.
But, assuming this is happening, someone should be able to heat gold coolant mixed 50/50 with distilled water in a controlled pressure vessel until it boils and see the results. If there is silicate residue left behind, then that could be evidence of a problem.
But Iv definatly seen 2 Diffrent color Substance (Like That) plugging an oil cooler
Ones in my pic and another in another members pics the Website used to let me post both but I think I can only do mine now I will try to get Both
its not cross contaminated from the cut either same stuff if you were to dig back in the junk plus the oil path is clear
Im thinking this is the casting sand
Here is one thats golden goo
<LINK rel=stylesheet type=text/css href="http://static.ibsrv.net/autocomm/vin_decoder/css/jquery.qtip.modified.css"><STYLE id=vbulletin_picturecomment_css type=text/css>.list_no_decoration { PADDING-BOTTOM: 0px; LIST-STYLE-TYPE: none; MARGIN: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px}DIV.fixed_width_avatar { TEXT-ALIGN: center; WIDTH: 60px}.content_block { PADDING-BOTTOM: 1px; PADDING-LEFT: 1px; PADDING-RIGHT: 1px; PADDING-TOP: 1px}.block_row { PADDING-BOTTOM: 6px; MARGIN: 1px 0px 0px; PADDING-LEFT: 6px; PADDING-RIGHT: 6px; PADDING-TOP: 6px}.block_title { MARGIN: 0px}.first_row { MARGIN: 0px}#message_list { BORDER-BOTTOM-STYLE: none; BORDER-LEFT-STYLE: none; BORDER-TOP-STYLE: none; BORDER-RIGHT-STYLE: none}#message_list LI { MARGIN-BOTTOM: 6px}#message_list DIV.fixed_width_avatar { FLOAT: left; MARGIN-RIGHT: 6px}#message_list DIV.message_avatar_margin { MARGIN-LEFT: 66px}#message_list DIV.info_bar { BORDER-RIGHT-WIDTH: 0px; MARGIN-BOTTOM: 6px; BORDER-TOP-WIDTH: 1px; BORDER-BOTTOM-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px}#message_list DIV.info_bar DIV.alt2 { PADDING-BOTTOM: 6px; PADDING-LEFT: 6px; PADDING-RIGHT: 6px; PADDING-TOP: 6px}#message_list DIV.info_bar A.username { }#message_list .message_date { FLOAT: right}#message_list .inlinemod_checkbox { FLOAT: right}#message_list UL.controls { TEXT-ALIGN: right; MARGIN-TOP: 6px}#message_list UL.controls LI { DISPLAY: inline; MARGIN-LEFT: 6px}#message_list UL.controls A:link { TEXT-DECORATION: none}#message_list UL.controls A:visited { TEXT-DECORATION: none}#message_list .deletedmessage { FLOAT: left}#qc_error_div { TEXT-ALIGN: left; MARGIN-BOTTOM: 6px}#qc_error_header { FONT-WEIGHT: bold}#qc_error_okay { TEXT-ALIGN: right}#message_form { MARGIN: 0px; DISPLAY: block}#message_form TEXTAREA { WIDTH: 98%; HEIGHT: 50px}#message_form DIV.messagetext { TEXT-ALIGN: left}#message_form DIV.allowed_bbcode { FLOAT: left}#message_form DIV.submit_button { TEXT-ALIGN: right}.picture_thumbnail { TEXT-ALIGN: center; WIDTH: 150px; PADDING-RIGHT: 6px}UL.vbmenu_popup LI { PADDING-BOTTOM: 4px; MARGIN: 0px 1px 1px; PADDING-LEFT: 4px; PADDING-RIGHT: 4px; WHITE-SPACE: nowrap; PADDING-TOP: 4px}UL.vbmenu_popup LI.first { MARGIN: 1px}#inlinemodsel { FLOAT: right}</STYLE><LINK rel=stylesheet type=text/css href="http://static.ibsrv.net/autocomm/gnr/2.3/gnr.css"><LINK rel=stylesheet type=text/css href="http://static.ibsrv.net/autocomm/gnr/2.3/jquery.lightbox-0.5.css" media=screen><LINK rel=stylesheet type=text/css href="http://static.ibsrv.net/autocomm/gnr/2.3/jquery-ui-1.8.11.custom.css"><!--Search Classifieds-->So what does this^^^^^^^
<!-- // Main vBulletin Javascript Initialization vBulletin_init();//--><!-- End Content --><!-- Begin comScore Tag -->
Ford Truck Enthusiasts Forums - bismic's Album: Coolant Filter
WTH was in there?
