Another E4OD question
Old Aug 25, 2012 | 04:54 PM
pnp522's Avatar
pnp522
Just replaced the trans in my 93. Tried to start it and the starter is hanging or something. Tried a different starter same thing happened. It has the 5.0 engine. Any ideas this is a new one for me.
Old Aug 25, 2012 | 05:30 PM
danr1's Avatar
danr1
Sounds like you didn't have the tc fully seated into the trans before installing it.
You should not have needed use the bell housing bolts to pull/force the housing up to the block.
To test, remove all TC to flex plate nuts. If you can move the TC back away from the FP a little bit move it around little bit its all the way in and not the problem. If you can not move it back away from the fp, can't move it at all not even a little bit? its not fully seated and you may have damaged the pump.
Old Aug 29, 2012 | 03:09 AM
pnp522's Avatar
pnp522
Thanks for the reply. Converter was seated. Took it to a shop via tow truck yesterday morning. They tried to start it and had same issue. They tried to start it this morning before it was put on the rack and everything worked fine. Started right up with no noise. The inspection cover was removed and there was no metal flakes or any evidence of gear damage. Not sure what it was but it seems to have solved itself wish everything worked like that! Still working.
Old Aug 29, 2012 | 12:31 PM
Truckin Bob's Avatar
Truckin Bob
Are you aware that there are two different starters for your truck ?
One is for a manual transmission and the other is (of course) for an automatic.
The "manual" version won't engage with the flywheel to turn the motor over with an automatic transmission.
Been there, done that with a NAPA store.
Just a tidbit to think about and double check.
Bob
Old Aug 29, 2012 | 01:47 PM
pnp522's Avatar
pnp522
Both starters were for autos. The one from my truck and the one from the truck as well. Both worked fine before the transmission was changed
Old Aug 29, 2012 | 01:48 PM
pnp522's Avatar
pnp522
Dang auto correct was supposed to say the one from the donor truck as well
Old Aug 29, 2012 | 05:27 PM
White 97 xlt's Avatar
White 97 xlt
Darn smartphones are NOT as smart as they think they are!!!!!
Glad you got your truck going...
slynch
2004 - 2008 F150
20
Sep 17, 2020 05:58 AM
Old Yblockman
Jul 12, 2017 07:36 PM
Beanscoot
1983 - 2012 Ranger & B-Series
Jul 13, 2012 02:05 PM
someday
General Automotive Discussion
Nov 7, 2008 07:42 AM
DROPDOUBT
Jan 4, 2008 07:20 PM
