Howdo i install a flexplate
Old Dec 31, 2007 | 06:38 PM
DROPDOUBT's Avatar
DROPDOUBT
I recently bought a 91 ford f150 with a 5.8l efi. has an automatic trans not sure witch one though. The guy had the trans rebuilt now it make a rotating clunking noise from the bell houseing. it has a problem starting also starter spins but wont engage when it does it stays engaged. im thinkin the flexplate was not put on correctly. maybe not torqued down enough but i have know clue. the convertor is tight aganst flexplate i checked that. can some help me?
Old Dec 31, 2007 | 06:44 PM
Virto's Avatar
Virto
You may be able to move the starter a bit to have better engagement. You can remove the starter and turn the engine by hand and look thru the starter hole and see the teeth on the flexplate to know what kind of shape they're in.
To get at the flexplate, you'll have to remove the transmission.
Old Dec 31, 2007 | 06:51 PM
DROPDOUBT's Avatar
DROPDOUBT
is there a certain way the flexplate goes on because of that counter weight
Old Jan 1, 2008 | 07:53 PM
RC Dan's Avatar
RC Dan
Since no one else posted, I will.
The flex plate is bolted on with 6 bolts to the crank, with offset holes, and can only be installed one way. Have you checked to see if the tranny is still bolted tight up against the block? I've seen a few come loose. Also check your starter and make sure the housing on it didn't come loose as well. And, since your down there, should check the 4 nuts on the torque converter, too. If all of that checks out, drop the starter out and make sure the return spring is still in one piece and that the gear slides smoothly.
Old Jan 4, 2008 | 06:06 PM
DROPDOUBT's Avatar
DROPDOUBT
the problem was my flexplate was broken so it was flapin around making a banging noise.
Old Jan 4, 2008 | 07:20 PM
quicklook2's Avatar
quicklook2
find out why it broke or it will happen again.
mortenauthen
Jul 23, 2013 08:04 PM
ginch66
Nov 6, 2011 01:41 AM
buffy.mike
18
Apr 4, 2011 05:13 PM
linckeil
Apr 27, 2006 08:46 PM
singer77355
Mar 17, 2004 12:11 PM
