97 power stroke stalling
Old Aug 24, 2012 | 03:12 PM
fordtks's Avatar
fordtks
97 Power Stroke stalls idling, intermitant cuts out while driving.Always starts back up. F350 4x4 single rear wheel, e40d, 114000 miles. Goes in spirts, may not fail for a month or 2.
Old Aug 24, 2012 | 03:30 PM
DarkStarMedia's Avatar
DarkStarMedia
Likely a CPS.... get one from ford or international...
Richard
Old Aug 24, 2012 | 04:15 PM
fordtks's Avatar
fordtks
Thanks for the quick reply. I had it to ford a while ago for CPS recall, they said it had been updated. I bought the truck used.I just assumed it couldnt be the problem. Thanks again
Old Aug 24, 2012 | 04:18 PM
DarkStarMedia
The CPS is easy, cheap, and quick to replace and if it doesn't fix the issue, you have a spare.
Based on your description it sound CPS-ish.
richard
Old Sep 17, 2020 | 08:01 AM
nativeamerican's Avatar
nativeamerican
darkstarmedia sorry new to this forum thanks for the info crank or cam tho
Old Sep 24, 2020 | 02:33 PM
nativeamerican
ok so this is where i am now. my 97 f 250 powerstroke is starting and will idle for about 15 min. then die. it starts rite back up will idle for a few seconds and die.. you can hear a difference in the motor and injectors. one second it loud like a diesel under the hood and the next it quiets like the injectors are covered with insulation and the rpms go up.. then the loudness comes back and rpms drop.. lost on this. and i can be driving down the highway and it will feel like it kicks it self out of O.D. but the light doenst flash.. then it kicks back in and rpms drop back down and run. once the temp gets above the first white line on the temp gauge it runs fine
Old Sep 26, 2020 | 01:14 PM
White95PSD's Avatar
White95PSD
[QUOTE=nativeamerican;19494788]ok so this is where i am now. my 97 f 250 powerstroke is starting and will idle for about 15 min. then die. it starts rite back up will idle for a few seconds and die.. you can hear a difference in the motor and injectors. one second it loud like a diesel under the hood and the next it quiets like the injectors are covered with insulation and the rpms go up.. then the loudness comes back and rpms drop.. lost on this. and i can be driving down the highway and it will feel like it kicks it self out of O.D. but the light doenst flash.. then it kicks back in and rpms drop back down and run. once the temp gets above the first white line on the temp gauge it runs fine
order the BAFX Bluetooth/WiFi code reader ($26 on amazon) it works with the FORScan (free) or (paid) app!! It displays code(s) if present. I would think a code would present with your symptoms. Works great for powerstroke. Best start to any diagnosis is a code. Many times I’ve researched and guessed replacing parts not needed.
jeremy
Old Jan 3, 2021 | 08:07 PM
spencer922's Avatar
spencer922
My truck does this exact thing as well. Did you ever find a solution to your problem?
Old Feb 9, 2021 | 08:31 PM
spencer922's Avatar
spencer922
https://youtu.be/HDQVMLqip3I
[***************]Went back through checked the harness. Could not find any noticeable nicks. Then I went to pull the chip and the wire had worn through on top of the emergency brake bracket. Wrapped it up and have not had trouble since. Granted it’s only been about 40 miles and 3 days...[/color]
Old Feb 9, 2021 | 09:27 PM
96 OBS's Avatar
96 OBS
sorry this thread must’ve been overlooked glad you got it figured out. Any loose connections or worn wires on the chips will cause serious running issues for sure
JRfore
Jul 9, 2012 05:54 AM
superduty4x4
Feb 27, 2009 12:07 PM
colorado solar guy
Jan 11, 2009 01:33 PM
Groundpounder0331
Aug 31, 2006 07:45 AM
FitOver50
Jul 28, 2005 08:58 PM
