FRONT END SHAKE
Old Aug 23, 2012 | 02:15 AM
djrod52's Avatar
djrod52
FRONT END SHAKE
MY 89 F-150 HAS A VERY STRONG VIBRATION WHEN GOING 35MPH OR BETTER WHEN YOU HIT A DIP OR POT HOLE ANY REMEDY FOR THIS
NO BRAKE APPLIED
Old Aug 23, 2012 | 06:04 AM
bashby's Avatar
bashby
Search "death wobble" Check for loose steering and suspesion parts.
Old Aug 23, 2012 | 09:51 AM
djrod52's Avatar
djrod52
All tie rod ends are new gear box tight
Old Aug 23, 2012 | 09:59 AM
djrod52's Avatar
djrod52
Could worn I-beam pivot bushings cause the "death wobble"
Old Aug 23, 2012 | 12:19 PM
bashby's Avatar
bashby
absolutely
Old Aug 23, 2012 | 04:35 PM
BrianDguy's Avatar
BrianDguy
Along with ball joints, wheel bearings, any of the radius arm bushings, or wheel and or tire balance or roundness.
Do not install a steering stabilizer to 'fix' the problem. It will only mask the issue.
Is your suspension stock?
Old Aug 23, 2012 | 05:19 PM
djrod52's Avatar
djrod52
Stock no modification
anthonym92
Mar 26, 2015 01:35 PM
Ric Carter
Feb 27, 2013 09:08 PM
kwandrsn
Tennessee Chapter
Jan 29, 2008 05:32 PM
SoloTSi97
1983 - 2012 Ranger & B-Series
Aug 10, 2005 08:45 AM
mudder trucker
Apr 18, 2002 12:59 PM
