1985 front end work
Old Feb 26, 2013 | 02:36 PM
Ric Carter's Avatar
Ric Carter
1985 front end work
I am just starting in on my journey working on my '85 F150.
The most pressing need, is to take care of some low speed front end vibration, clunk, and shake.
I just crawled under to take a look at. The tie rod, and tie rod end seem to have a lot of rotational play in them. The drag link doesn't have nearly as much rotation.
Do you think this would be the problem?
Thanks.
Old Feb 26, 2013 | 03:57 PM
xjfever's Avatar
xjfever
That could cause the shake, but I doubt it is causing the clunk and vibration. The wheel hubs u-joints, would be more likely for the vibration and the bushings, shocks for the clunking.
Old Feb 27, 2013 | 06:26 AM
9wire's Avatar
9wire
I have a clunk in mine, but can't tell if it's front or back. The weather and work haven't been cooperating either.
Old Feb 27, 2013 | 08:02 AM
bashby's Avatar
bashby
Check for an out of round tire, worn tie rods don't cause vibrations usually.
Old Feb 27, 2013 | 07:24 PM
85blackbeauty's Avatar
85blackbeauty
Clunk in the front end
My '85 also had a clunk in the front end, especially when going from drive to reverse and vice-versa. The problem was that the radius arm mounts had worn until they were out of round, causing the radius arms to be loose. When I switched from D to R, they would move in the mounts, making the clunk. These mounts can be ordered from most parts house, including Rock Auto. The vibration and shake can be caused by all the things that have been mentioned in prior responses, some of my issues were caused by worn upper and lower ball joints. Good luck!
9wire's Avatar
9wire
I'm wondering if my spare tire is clunking.
Old Feb 27, 2013 | 07:39 PM
Ric Carter's Avatar
Ric Carter
I kind of wonder if some of it is just that I haven't drove any older vehicles for years, and I may not be used to how it drives yet. I drove it today, with very little shake or rattle. I will take it to a pro to look at tomorrow, before I go trying to do something I'm not smart enough to do.
Old Feb 27, 2013 | 07:46 PM
1983F1503004x4's Avatar
1983F1503004x4
9Wire, that makes for a simple test. Just remove it and take it for a drive to find out.
Typically, clunking from the rear of the vehicle is the rear differential being worn.
A lot of people who've had these trucks before us neglect to maintenance the parts that don't require oil or automatic transmission fluid. Oh, they'll have the front end greased and an alignment done occasionally, but they forget to do wheel bearings, u-joints, ball joints, bushings, etc.
Old Feb 27, 2013 | 09:08 PM
9wire's Avatar
9wire
Might take it to the co-op and borrow their lift, give it a good going over. I'm thinking it's the radius arms, seems to be fairly common.
boatnfish
1997 - 2003 F150
Jan 23, 2009 07:18 PM
92aeroXLT
Aerostar
Nov 19, 2004 01:56 PM
92EBnTX
1978 - 1996 Big Bronco
Nov 6, 2004 07:25 PM
desperado_18_2000
Jul 5, 2003 11:50 AM
mudder trucker
Apr 18, 2002 12:59 PM
