What is this??
Old Aug 22, 2012 | 08:01 PM
detract's Avatar
detract
Question What is this??
I have an 04 F150 5.4
For the first time I've had to use my spare tire. When I lowered it down I noticed a small chunk of cast metal in the rim, then noticed an electrical unit hanging by the wires under the frame. The chunk of metal was part this units housing which now exposes the circuit board inside.
I unplugged it and turned it sideways a bunch of sand poured out, so it's been exposed to the elements for some time now.
Question is what is it? and do I need it?
Like I said it looks like it's been full of water so I doubt it has worked in a long time. I have no trouble codes or other odd things showing up on a diagnostic scan.
It has some heavier gauge wire to it... Ideally if I don't need it I'll just simply leave it unplugged and cap the connector.
Here are some pics looking up from the back. Yes it's rusty, it's a farm truck in Ontario so it takes a beating.
Old Aug 22, 2012 | 08:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
It's the fuel pump controller, replace it before it craps out and leaves you stranded.
Old Aug 22, 2012 | 08:57 PM
danorules's Avatar
danorules
Agreed, fix it now
Old Aug 22, 2012 | 09:04 PM
1969furd's Avatar
1969furd
so that is what that hing is good to know
Old Aug 22, 2012 | 09:17 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I was a little of on the name, it's a fuel pump drive module. They are notorious for doing what your's has done, cracking and breaking up, water and dirt gets inside and they fail. When they do all you can do is coast over to the side of the road.
What causes them to break is the cross member they're attached to is not flat, the module is rigid. When they install it on the assembly line and tighten it down, the unit is stressed and eventually cracks.
Most replacement units have spacers that are installed under the mounting screws to keep this from happening again.
Old Aug 22, 2012 | 09:24 PM
1969furd's Avatar
1969furd
ah, so is this part a dealer only part?
Old Aug 22, 2012 | 09:27 PM
shorebird's Avatar
shorebird
Old Aug 23, 2012 | 05:42 PM
detract's Avatar
detract
I just want to thank everyone who responded. I have a 10 hour drive ahead of me Saturday and I picked up and installed the new module today, got my tire patched and things are looking good!
I don't know how this thing was still working, I swear there was a tablespoon of sand inside it.
Cheers!
Old Aug 23, 2012 | 08:27 PM
Greg B's Avatar
Greg B
You must live a clean good life, detract. It definately was an act of God that kept the fuel pump working.
Old Aug 23, 2012 | 09:25 PM
1969furd's Avatar
1969furd
can this little box be relocated
Old Aug 25, 2012 | 12:38 AM
Greg B's Avatar
Greg B
It probably can, but the replacements are insulated against vibration and stress and seem to last much longer.
Old Aug 25, 2012 | 05:45 PM
02transam's Avatar
02transam
I see a lot of rust........
brickman
Jul 17, 2019 11:47 AM
Rickster800
1947 and Older Ford Trucks
Dec 5, 2016 11:54 PM
xjcamaro89
2004 - 2008 F150
Jun 21, 2013 12:51 PM
mercman86
2004 - 2008 F150
Oct 2, 2011 04:24 PM
Nathan Plemons
23
Jun 22, 2009 10:57 AM
