Sponsored by: Real Truck
Need Help Please
Old Aug 22, 2012 | 07:16 PM
notabeanr's Avatar
notabeanr
Exclamation Need Help Please
I have a problem if anyone could help me. I have an 04 f-250 6.0 diesel king ranch. The turn signal will not come on at all. The hazards work and so do the lights and brakes lights. As well as the windshield wipers. I have replaced the relay behind the radio and also the signal switch assembly as well. Checked all fuses and all are fine. Is there another relay and if so where is it located? Just trying to narrow all options before bringing it into the dealership.
Old Aug 23, 2012 | 06:00 AM
redford's Avatar
redford
FTE Leadership Emeritus
You can download a free copy of your owners manual here.
http://www.motorcraftservice.com/pub.../04f23og2e.pdf
It shows the location and purpose of all the fuses and relays.
Did you replace the multifunction switch? Did you check the condition of the wiring inside the steering column/?
Old Aug 23, 2012 | 07:32 PM
notabeanr's Avatar
notabeanr
i have the owners manual and have checked all fuses and relay. I did replace the multifunction switch if you are referring to the switch attached to the steering column that turns on your wipers and high beams yes. The wiring inside the steering column looks normal checked it all over and see no wires that may be cut or anything wrong with them. Now today as i started my truck the ac will only blow air from defrost vents. Are these two things in conjunction or do i now have 2 different problems.
Old Aug 24, 2012 | 05:53 AM
drey04's Avatar
drey04
You probably have a vacuum leak.
Old Aug 24, 2012 | 03:00 PM
notabeanr's Avatar
notabeanr
Angry
so once again I am trying to figure out this signal light why it will not work. I have already Done all of the above and in addition to i have check the voltage and i am getting 12 volts On the blue and green line that connect to the multi-function switch. Any help that anyone can assist me with this please i would appreciate it.
Old Aug 24, 2012 | 03:56 PM
Yahiko's Avatar
Yahiko
One thing that would help you would be the wiring
diagram for your truck. Not the junk one that can
be found in the Hanys/Chiltons manuals. Because
they tend to not be that good and reliable . You
want the Ford Shop copy.
A good place to start asking would be here because it a
6.0L Diesel >>> 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You could also look on Ebay. I found both of the copies for my 2 Ford trucks
there and one is a 2006 6.0L Diesel. I found this one for your truck
2004 Ford F-250 F-350 F-450 F-550/Super Duty Wiring Diagrams Manual_Gas/Diesel | eBay
Even if you end up taking it into Ford this can be very handy for other things.
Please do come over and visit us at the 6.0L Diesel Forum.
Sean
Rikster-7700
Nov 22, 2021 11:00 PM
bryansshort
Electrical Systems/Wiring
Jul 2, 2015 08:58 AM
Chris Mendez
Apr 13, 2014 01:21 PM
Phanman43
Mar 4, 2014 07:08 PM
4fords
1997 - 2003 F150
May 8, 2008 09:03 AM
