E4OD- shaking after shifting
Old Aug 22, 2012 | 12:40 PM
baki-winnie's Avatar
baki-winnie
Hello from Germany.
I have a problem with my transmission and can not find the problem.
The transmission shifts smooth, but then directly after the shift, there is a shaking like a vibration for a little time. (You can feel it best ca. 50miles/h).
If I press the speed panel a little more it directly appears, ohterwise it takes some time to disapear itself.
The same thing I get, if the car changes from no load operation to speed up, and ther is not changing a gear.
I think it is something wtih the transfer of the torque.
I checked the oil, it looks fine, almost clear like water.-> no burnings
I checked all the harnesses, nothing to see all fine.
I checked the cardan and cardan joints, all is tight.
Any suggestions, what it is? I have no ideas left.
Thanks for the answers
Gruß
baki-winnie
E350, 7,3l Diesel 1992 with E4OD
Old Aug 22, 2012 | 08:36 PM
yorska's Avatar
yorska
On a guess, I would say torque converter shudder. The converter is a semi weak spot in the e4od. It is not really weak, but seems like one of the first parts to wear out.
Search "e4od converter" and see if it matches your symptoms.
Old Sep 19, 2012 | 05:15 AM
baki-winnie
Hello yorska,
thanks for the hint.
I found a discription of a liquid and filled it in my tranny.
Now it works fine, now shaking left.
Thank you for helping.
Billybob12
1978 - 1996 Big Bronco
Apr 17, 2010 01:05 PM
zon9
1997 - 2003 F150
Sep 13, 2007 01:29 PM
darrin1999
May 12, 2007 06:25 AM
fordtruckboyf150
26
Mar 19, 2007 08:14 PM
LogicalRetard
Feb 12, 2006 07:42 PM
