Extended Crank Time
Old Aug 21, 2012 | 10:39 PM
FordMan35's Avatar
FordMan35
Extended Crank Time
Recently I have had a problem with needing to crank the engine longer before it lights. I pulled a P0341 and P1335. I cleaned the EGR valve and replaced it. When the engine does start there it almost always a puff of black smoke out of the exhaust, and when the engine is cold I believe there it be a raw fuel smell to it. Can a fault with the CMP sensor/circuit cause this or do I need to look at something else? Also want to mention I am getting slightly better fuel economy than usual.
Old Aug 23, 2012 | 02:03 AM
Fordflanigan's Avatar
Fordflanigan
Check the FICM volts and the batteries. Start easy first. I'd also start looking into possible hpo leaks. Black smoke sounds like possible FICM though
i had p1335 a few months back, I cleaned and the code came back a few miles later. Ended up replacing the valve.
Old Aug 23, 2012 | 06:30 AM
bismic's Avatar
bismic
P0341 : CMP electrical issue (connector, wiring, or possibly the sensor)
GOODOLEF250
17
Jun 22, 2019 04:52 PM
Arbo13
Aug 17, 2016 09:59 AM
strokersace
60
Dec 14, 2009 09:13 PM
hanlinhound
Apr 9, 2009 04:26 PM
g0ldrush
Sep 7, 2004 08:56 PM
