Starting my 76 Highboy DT360 swap
Old Aug 21, 2012 | 08:41 PM
MTeichmeier's Avatar
MTeichmeier
Got started to day on the tare down of the Highboy so i can try to get most of the swap done before heading back to school
Truck: 76 highboy 390, 4 speed, a/c, flatbed
Engine: 87 dt360 international, spicer 4054d 5 speed
Old Aug 21, 2012 | 08:46 PM
MTeichmeier
Tare down
Hopefully tomorrow i'll get the 390 pulled and get the DT in place and start building mounts
Old Aug 21, 2012 | 09:24 PM
spikinfool05's Avatar
spikinfool05
looks like a good swap where in ne are you at.
Old Aug 21, 2012 | 09:31 PM
MTeichmeier
hopefully it'll all go well and i'm south central around the keareny area
Old Aug 22, 2012 | 03:14 PM
spikinfool05
south of keareny like gibbon
Old Aug 22, 2012 | 08:41 PM
MTeichmeier
Well didn't get as much done as i hoped but got the 390 out with the tranny, motor mounts, and all the crossmembers but the first so tomorrow I can set the dt in and see what all i'm going to have to do to make it fit.
Ok so the reason for the swap is so that i'll have a dependable truck to haul around all my other toys, so the DT will get the "A" pump turned up and a better turbo for the time being until i can get the kinks worked out then it'll be getting a P pump and more air
Old Aug 22, 2012 | 09:02 PM
Fordworth's Avatar
Fordworth
Cool swap. FYI, if you remove the entire front clip it makes things a whole lot easier. It's too late now but you can pull the whole clip in one piece with the inner and outer fenders, core support and grille all together. Then you have full access like this.
<a href="http://s742.photobucket.com/albums/xx65/Fordworth/1975%20Ford%20Highboy%20Cummins%20ZF5%20Swap/?action=view&amp;current=IMG_20110605_150236.jpg" target="_blank"><img src="http://i742.photobucket.com/albums/xx65/Fordworth/1975%20Ford%20Highboy%20Cummins%20ZF5%20Swap/IMG_20110605_150236.jpg" border="0" alt="Photobucket"></a>
I hope you have plans to swap out the rear axle too, you're gonna need it to avoid this.
<a href="http://s742.photobucket.com/albums/xx65/Fordworth/D60%20Destruction/?action=view&amp;current=2012-02-06_19-11-04_608.jpg" target="_blank"><img src="http://i742.photobucket.com/albums/xx65/Fordworth/D60%20Destruction/2012-02-06_19-11-04_608.jpg" border="0" alt="Photobucket"></a>
Old Aug 22, 2012 | 09:18 PM
MTeichmeier
Yeah i was going to take the whole front clip off but it turned out the rad support is rusted to the point of trashing and i was hoping it'd help with showing what all will need modified.
Dang thats quite the break, i was hoping to get by with the 60 rear for a little while but i have a D80 in my mud truck that might be getting rockwells so i guess i'll see where it goes
Old Aug 22, 2012 | 09:35 PM
Fordworth's Avatar
Fordworth
Good idea. That was the result of a moderate 6BT, a heavy foot and bang shifting into third. It didn't happen the first time but it didn't take long.
Old Aug 23, 2012 | 07:28 AM
teds74ford's Avatar
teds74ford
Subscribing.
Old Aug 23, 2012 | 09:46 PM
MTeichmeier
Well not a lot to report tonight got cought up on the farm and had to work on the family's stuff, so only really got done with cleaning up the frame a little and removing the extra crap on the trans like the pto that's going to end up right in the way of the front drive shaft or i would've put a big old pto winch under the bed
Don't worry the oil is from when my brother tried to change the oil in one of the big trucks
http://i1145.photobucket.com/albums/...g?t=1345776085
almost a shame it's getting more use as a tool bench
Old Aug 24, 2012 | 04:32 PM
MTeichmeier
Ok set it in as far as i could without any cutting or body lift to get an idea and realized just how much cutting its going to take without the lift, so kinda suck right now on what to do
this as far as I could go with the trans on before the oil pan was sitting on the front crossmember
view of the pan sitting on the CM
here's the clutch housing and mid engine mounts about 4" in front of the firewall but they should be directly under with where i want to mount it
A little bit of good news, it looks like the trans shifter should end up about dead center of the trans opening
and finally i pulled the trans in hopes that it'll make it a little easier to get the engine where i want it then make the trans fit some how
Anyone got any ideas or advice for a newbe like me?
Old Aug 24, 2012 | 04:35 PM
MTeichmeier
Oh and whats a decent price for a leak free running 390 and 4 speed, because i have a buddy that wants it bad but i don't know what they are worth anymore? Thanks
Old Aug 24, 2012 | 04:53 PM
Fordworth's Avatar
Fordworth
The crossmember has to come out for sure. That's true of Cummins swaps also and I believe your engine is a bit bulkier. Some people modify the crossmember but I cut mine out completely and made a new one.
Old Aug 24, 2012 | 08:52 PM
MTeichmeier
fordworth where did you put the new crossmember in the pic you posted i can see where you cut it out but not the new crossmemeber and do you have any pics
