Sponsored by: Auxito
Exhaust question
Old Aug 20, 2012 | 11:22 PM
Lostintime123's Avatar
Lostintime123
Exhaust question
I just bought a 1997 f150 4x4 lariat edition with the 5.4 liter motor in it. And I notice that the exhaust is just a straight pipe the exits right in front of the passenger rear tire. My question is: is this bad for the truck? Would I benefit from purchasing an actual exhaust system from the cat back?
Old Aug 21, 2012 | 07:44 AM
redwood's Avatar
redwood
No muffler and no cats?
Old Aug 21, 2012 | 01:54 PM
Bluegrass 7's Avatar
Bluegrass 7
Get under and look at the whole system.
Are there two cats each side?
Is there a muffler?
You have not given very much info other than a 'notice'.
Good luck.
Old Aug 21, 2012 | 03:10 PM
redwood's Avatar
redwood
IIRC, the exhaust pipe on the 97 exits in front of the PS rear tire from the factory. Like Bluegrass said, more info is definitely needed....
Old Aug 21, 2012 | 05:04 PM
Lostintime123
I has the cats underneath it... just right after the cats it is cut and has a pipe welded onto it that exits before the tire... has no muffler
Old Aug 21, 2012 | 05:46 PM
Spotty's Avatar
Spotty
Sounds like someone just took off the muff and replaced it with a piece of pipe. 97 did exit in front of the tire. I don't see any advantage in replacing it except maybe for the stock sound...????. As long as the cats and all o2's are in place I don't see a performance issue either direction.
Old Aug 21, 2012 | 06:09 PM
Lostintime123
I like the sound of it so that's not the issue. I just read somewhere on another thread that it wasn't good for these motors to run without a muffler.
Old Aug 22, 2012 | 05:26 AM
BFTUFF's Avatar
BFTUFF
If the right amount of back pressure is not present the engines performance will suffer, less power and worse milage. Less back pressure is one thing, to a point. But removing all back pressure in a stock motor will definitely ruin overall performance. Put some type of Turbo muffler back on it, and exit in front of the LR wheel. Mine is set up that way and I get good milage, sound, and plenty of power for an engine with 196,000 mi. on it.
Old Aug 22, 2012 | 06:00 AM
Lostintime123
Well I crawled under and gave it a closer look.. all the did was cut the muffler off and weld a piece of pipe in place of it. Looks like a homemade job and whoever did it was not a good welder. I'm a big flowmaster fan so I believe ill be looking into buying a flowmaster for it. I also like the sound of hooker mufflers.. may get one of those.
HoodRider
Apr 22, 2013 06:24 PM
flatbed90
Apr 11, 2008 05:04 PM
whiskeyrichard
Feb 4, 2007 11:34 AM
Josh0525
Nov 12, 2005 03:44 PM
Juggalo4life
Exhaust Systems
Feb 10, 2004 11:15 AM
