tps bad?
Old Sep 17, 2002 | 09:28 PM
little_johnny's Avatar
little_johnny
tps bad?
ruff idle/poor acceleration...got codes 41(02 sensor),63 tps signal too low. got out the old Haynes to check tps. at idle-.945v full open-4.5 volts...within range according to the book. It also says to check the resistance...said it should go from 3.5k ohms down to around 350ohms wide open. Mine never moved from 3.5k......is this possible? For the voltage to be right and resistance off? Kinda thought they moved hand in hand.
Old Sep 17, 2002 | 10:28 PM
standman's Avatar
standman
tps bad?
I can't imagine the tps causing it to idle rough.Not sure about acceleration.Sounds more like air idle bypass valve or the egr valve to me.Sure you didn't get some bad fuel???
Hope this helps.
Clay
Old Sep 18, 2002 | 12:23 AM
reddevilf150's Avatar
reddevilf150
tps bad?
Slomoe
Dec 12, 2013 06:06 PM
Chaos 95
20
Nov 21, 2012 10:32 PM
R.J.M.
Sep 24, 2011 04:21 PM
hogan1967
Jan 29, 2011 10:25 AM
nomad221
Sep 2, 2009 03:36 PM
