A week ago I took my 04 f350 6.0 to the drag strip for the first time. I noticed as I tried to stage the truck in the staging lights, I power braked it to build boost and the boost was somewhat sluggish to build-up. If I hold it long enough (10 or more seconds) it will hit max boost and launch and run like a bat out of hell. If I repeat the power brake it improves and the boost will come up quicker. But If I drive it for a while or the truck sits for a while, I'm back at square one.
Does this sound like I'm in need of cleaning the turbo?
While I've got the turbo out, is there anything else I should replace/update while I am in there, like the turbo oil supply tube, turbo oil return tube, ???
guys please I do this all day long you dont need any parts kit.
a diegrinder and small pads. that is it. do not take the aluminum housing apart. I have some pics of my 03 turbo split I just cleaned If you need them posted let me know.
split the castiron housing remove the the unison ring clean both sides. clean the vains. clean both inside serface of the center housing and reassemble. dont make it harder then it needs to be. 20-30 min job once its off.
Thanks cheezit.
The kit I listed contains only the pads, emery cloth, and a paint pen.
Hey Mark, I used the same kit 4C4Z-9V424-AA It came with everything O-rings for oil return tube; gasket for oil inlet tube; New clamp for turbo housing; 3m kit; new mounting bolts bolts for turbo. caps to close all inlet and outlets while cleaning to keep out dirt can't remember what else. No Paint Pen!!!!
The kit does contain a new bandclamp and mounting hardware.
William04X found the kit (some time ago) on ebay for $10 (as an fyi)
Edit - you beat me to it Rocky! (thanks)
The article (http://www.forddoctorsdts.com/articl...icle-06-05.php) indicates that the kit was limited to the cleaning parts. Clearly changes were made in the content (and way more than the $10 at Lowes - unless you find an ebay deal)!
The article (Diesel Technician Society) indicates that the kit was limited to the cleaning parts. Clearly changes were made in the content (and way more than the $10 at Lowes - unless you find an ebay deal)!
Your the one that gave me the part number about a year ago..Thank You
