Another MPG Thread
Old Aug 22, 2012 | 10:49 AM
Horseyfella's Avatar
Horseyfella
Originally Posted by Tugly
Click that last link on my signature.
Tugly, that mileage is excellent. I've read the link in your sig and I'm slowly creeping up, 15 highway after replacing ebps with faulty readings. Anyway I've noticed in your pic, speedo at 65 your around 1900 rpm. I'm at 2100 @ 65 with 4.11 gear. I'm guessing you have a taller gear attributing to better mileage?
Old Aug 22, 2012 | 11:04 AM
Christof13T's Avatar
Christof13T
I think he is running 3.73 ratio.
Xtof
Old Aug 22, 2012 | 11:37 AM
Big Red 7.3's Avatar
Big Red 7.3
NOT but is there a way to tell the gears in the rear per say? I thought I read it how to tell but due to short term memory loss I forgot. I am running much less at 65 but have huge tires which does change ratio. I do know that my speedo is 3-4 MPH slow to the real time gps.
Old Aug 22, 2012 | 11:39 AM
pin8246's Avatar
pin8246
Originally Posted by Big Red 7.3
NOT to but is there a way to tell the gears in the rear per say? I thought I read it how to tell but due to short term memory loss I forgot. I am running much less at 65 but have huge tires which does change ratio. I do know that my speedo is 3-4 MPH slow to the real time gps.
If I recall right there should be a tag on the rear diff that has numbers stamped in it. Get those numbers off and they translate to ratio and a couple other things.
Old Aug 22, 2012 | 11:42 AM
BigAlsPSD's Avatar
BigAlsPSD
Tag on the Differential, or you may have it under "Axle Code" on the build sticker in the driver's side door jam.
Old Aug 22, 2012 | 10:28 PM
Tugly's Avatar
Tugly
I looked on the differential some time back and it said I have 3.73, but I can't remember how it was marked to know that.
Old Aug 23, 2012 | 10:46 AM
Gatrucknut's Avatar
Gatrucknut
Rear tag should have 3L73 meaning 3.73 ratio with limited slip. If no LS I believe there is only a space. If there is no tag on the rear, the calculator will get you close enough, otherwise, the tag was removed and you really wont know except to open it up.
With my 37" and 3.73 gear I am running 1750RPM at 68MPH per the GPS, 65 per calculation.
Here's a link to the calculator: Interactive RPM and MPH Computator Program
The effective gear ration for our 4R100 in OD is 0.80.
Old Aug 23, 2012 | 11:34 AM
Big Red 7.3
I know on the door tag under Axle it has nothing. I will check on rear axle today. I think I found the tag just to the right of the pumpkin from the rear of truck but someone painted over it.
Old Aug 23, 2012 | 11:54 AM
Gatrucknut's Avatar
Gatrucknut
The tag I am referring to is a metal dog tag on the a rear diff cover bolt.
Sorry , I havent quite figured out how to insert a pic.
Old Aug 23, 2012 | 12:38 PM
Big Red 7.3
This truck has aftermarket covers by Mag-something. Rear Diff, trans and the oil pan. Nice items and the rear has a dipstick but no dog tag to be seen. Same here, I need to learn how to insert pics as well.
97haymachine
May 25, 2013 03:38 AM
TheTinian
23
May 21, 2013 08:36 PM
caseydudem
Jan 9, 2011 04:22 PM
kickergt
15
Jan 15, 2008 03:51 PM
viperbluelx
20
Jan 13, 2008 09:31 PM
