97 f-150 won't idle in drive
My 97 F-150 won't idle in drive, as a matter of fact when you stop at a red light it sometimes dies. I read other post that suggest this is the TCC solnoid (Torque Converter Clutch). I think thats what my problem is also, but would like to confirm it by doing a continuty check of the solnoid. Does anyone know the wiring diagram for this solnoid? I would like to check it from the PCM module if possible. Also I been told this valve can be easily replace by dropping the transmission pan then simply unbolt, unplug. Is it that simple?Ford has priced me one for $47.99.
IT's kind of like a manual thats left in gear.
But a better descripition would be once I start the truck it idles at about 700rpm, then once I put it in gear it drops to 500 or so, then if I slightly depress the pedal to move foward and then release the pedal the rpm goes to about 1000rpm when I move foward, then when I release the pedal the rpm's drop to maybe 100 or 200 and sometimes the truck dies.
Think the guys are on key with the IAC, I had mine tuned up when the check engine light started glaring at me, which was on 'cuz of a bad IAC. Before then, the truck wouldn't budge while idling, in forward or reverse. I just assumed it was from my 4.6 being tired out at 133k miles. After the tuneup and IAC replacement, the truck can almost roll itself into 2nd gear just idling.
I also just had my heads, left and right rebuilt and am now having a idle problem. After reading these posts and looking in my manual I found a section on IMRC actuator. It also controls airflow and is located in back of the plenum. This part has a grommet that I damaged and patched with modified hardware store parts. Ill check it again tomorrow morning. This might be my problem, and yours.
Dave
Dave
Dave
Dave
Finally a little luck. The IMRC regulates air flow above and below 3000 rpm, not affecting idle speed
yzf600rguy
23
03-28-2012 03:47 PM
1dibbs
09-30-2009 08:13 PM
blang
1997 - 2003 F150
03-25-2009 09:03 AM
jokerr
10-24-2002 01:21 PM
