97 f-150 won't idle in drive
My 97 F-150 won't idle in drive, as a matter of fact when you stop at a red light it sometimes dies. I read other post that suggest this is the TCC solnoid (Torque Converter Clutch). I think thats what my problem is also, but would like to confirm it by doing a continuty check of the solnoid. Does anyone know the wiring diagram for this solnoid? I would like to check it from the PCM module if possible. Also I been told this valve can be easily replace by dropping the transmission pan then simply unbolt, unplug. Is it that simple?Ford has priced me one for $47.99.
Hi mjpinksto and welcome to FTE :)
What does it feel like when it dies? If the TCC is stuck on it will feel like if you were driving a standard and forgot to push in the clutch when you stopped. |
whoa there partner. I'd say your Idle Air Control is about to call it quits. This part is on the back of your throttle body, with 2 or 3 bolts securing it, and an quick snap electrical connection. About $75 from the dealer, autozone aint got it.
IT's kind of like a manual thats left in gear.
But a better descripition would be once I start the truck it idles at about 700rpm, then once I put it in gear it drops to 500 or so, then if I slightly depress the pedal to move foward and then release the pedal the rpm goes to about 1000rpm when I move foward, then when I release the pedal the rpm's drop to maybe 100 or 200 and sometimes the truck dies. |
That does sound more like an IAC problem. I think I'd be looking in that area first.
Let us know what you find. |
Think the guys are on key with the IAC, I had mine tuned up when the check engine light started glaring at me, which was on 'cuz of a bad IAC. Before then, the truck wouldn't budge while idling, in forward or reverse. I just assumed it was from my 4.6 being tired out at 133k miles. After the tuneup and IAC replacement, the truck can almost roll itself into 2nd gear just idling.
I also just had my heads, left and right rebuilt and am now having a idle problem. After reading these posts and looking in my manual I found a section on IMRC actuator. It also controls airflow and is located in back of the plenum. This part has a grommet that I damaged and patched with modified hardware store parts. Ill check it again tomorrow morning. This might be my problem, and yours.
Dave |
Originally posted by dave2002 I also just had my heads, left and right rebuilt and am now having a idle problem. After reading these posts and looking in my manual I found a section on IMRC actuator. It also controls airflow and is located in back of the plenum. This part has a grommet that I damaged and patched with modified hardware store parts. Ill check it again tomorrow morning. This might be my problem, and yours. Dave Finally a little luck. The IMRC regulates air flow above and below 3000 rpm, not affecting idle speed |
