Tri-Carb 300 inline six
Old Aug 19, 2012 | 05:26 PM
Kustomfiend's Avatar
Kustomfiend
I have a bee in my bonnet and this thread is purely for my own curiosity and thirst for info. I've found a number of threads pertaining to increasing and improving the performance of a 300 inline six, but not much eloboration. Good reference photos!
I'd like to build a tri-carb intake manifold and will be implementing my existing knowledge of V8 performance to an inline six:
  1. rectangular runners: rectangular tubing, mandrel bent and laser cut seats for the carbs to be mounted on
  2. longer runners for increased low-end: taking my cue from a high rise intake manifold
  3. polishing and grinding plenums for the usual reasons
  4. 1/2 inch riser for each carb
  5. blending each runner, so one carb feeds two intakes at a time
I'll be building this out of steel and have it electroplated/ galvanised for rust prevention. Am I missing something? Or bad idea?
What carb would be ideal for such a set-up? Rochester 97's (favored amongst many hot rodders) or Weber single barrels? Or a triplet of standard Carters/Motorcraft carbs?
I also intend to fab up a header and add a performance cam and performance ignition set-up to the mix.
Would this work?
Any advice and tips would be muchly appreciated.
Old Aug 19, 2012 | 05:38 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Check this thread:
https://www.ford-trucks.com/forums/6...s-running.html
Old Aug 20, 2012 | 06:32 PM
fordman75's Avatar
fordman75
I'm going to be building something similar on my 300. I'm also building my own headers. So I'm going with a single mounting flange for the header and intake.
I'd skip the whole electroplating or galvanizing idea. If you want to have it coated go with a ceramic coating inside and out. And there's not really any reason to polish the intake plenums.
I'm going with some mandrel U-bends exhaust tubing for my runners. I'm going to try and flatten out the sides on them some. Might not be perfect but it'll be a little easier/quicker for me. Mine going to be a daily driver not an all out drag car so it should be fine.
My plan is 3 separate plenums for the carbs. I haven't decided yet if I'm going to divide the plenums to separate the ports or not. I'm going to build the plenums out of some sheet metal and am going with 1/2" plate for the carb mounts/risers.
Personally I wouldn't mess with rochestors or Weber 1V's ( Now if you are talking some DCOE's or IDA/IDF's 2V's then sure! ) . For my set up I'm going to run 3 Autolite 2100 2V carbs. The Autolite 2100's are super simple, perform good and very reliable. Then once I get the supercharger set up finished/engine for it built I'll be swapping over to 3 Holley 4412 2V carbs.
When you build your take lots of pictures and post them.
Old Aug 21, 2012 | 05:43 AM
willowbilly3's Avatar
willowbilly3
"Longer runners for increased low end"? really? I always thought they were longer for better top end like the high rise and tunnel ram intakes on V8s.
How about 3 side draft carbs. each on it's own 2 into one. Three S&S carbs from Harley Davidson maybe?
Old Aug 21, 2012 | 02:11 PM
fordman75's Avatar
fordman75
Longer runners are good for torque. That's one of the reasons the Ford EFI truck intakes have such long runners.
I think the V8 tunnel rams are more about plenum volume then it is runner length.
Old Aug 28, 2012 | 11:05 AM
TheDudeAbides's Avatar
TheDudeAbides
what about a set of three glass bowl holleys? they'd look pretty sweet!
Old Aug 28, 2012 | 11:49 AM
fordman75's Avatar
fordman75
Not much of any performance to be gained with three glass bowl Holley's.
The Autolite 2100's are a good performing simple/reliable carb. And they came in enough different sizes to size them to your engines need.
Mr_KnowNothing
Jun 29, 2014 12:27 PM
sean2857
Aug 1, 2011 09:08 PM
Zerojunk
Oct 25, 2007 03:06 PM
77'Sam
13
Aug 29, 2006 11:22 PM
usmc_ford
Apr 13, 2003 04:43 PM
