Got a Pop Tester?
Old Aug 19, 2012 | 01:44 PM
whalebus2112's Avatar
whalebus2112
Got a Pop Tester?
I would like to get my injectors pop tested. I needed 1 new injector because some one screwed the threads up where the line goes on but I found a deal for all 8 injectors for $100 so I got that.
I got them on ebay from Pensacola and I have read all the disputes with them but for the money I couldnt go wrong.
I replaced the leaky injector and it works fine but I would like to get the others tested before I go threw the hassel of replacing them all and some might not be good.
They are all differnt codes but they say the guts are all the same as I am sure you all know.,,,,so,any one out there I could send these to with some beer money and get them tested? No one local has the set up so. Let me know and help a brotha out
Old Aug 19, 2012 | 01:54 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Some options,
I got lucky and found a shop to test mine. The best thing was the test was free, and all my injectors tested good!
Here is one option, it doesn't look too expensive or difficult:
PeachPartsWiki: How to build a Diesel Injector Pop Tester
I know that Eaton (username eaton9999) and Russ, (username typefour) both have them, you might try to PM them.
Good luck,
Mac.
Old Aug 19, 2012 | 06:51 PM
whalebus2112
It amazes me what poeple come up with. Thats a cool tester but a little more in depth than I would like. Thanks for the link and I will pm those guys if they do not pop up and comment
Old Aug 19, 2012 | 07:00 PM
akamacgyver
Clueless spectator!
Yeah, that is a lot of work for as much as you would need one. If I were to get into rebuilding them or the likes, but I'll stick to finding someone to do it for me. I think my first project when I get settled in Denver is trying to find WVO for bio-diesel!
_Clayton_'s Avatar
_Clayton_
I got a pop tester if you wanna send me a pm we'll work something out.
Old Aug 20, 2012 | 01:53 AM
maverick1701's Avatar
maverick1701
you might check with at your local highschool auto shop or college ag mechanic shop...they might have one that you can use (we did at SFA) or they might even test them for you and use it as a learning experience for the kiddos.
Old Aug 20, 2012 | 07:17 AM
whalebus2112
Thats a good idea
Old Aug 20, 2012 | 07:18 PM
whalebus2112
Pmed you Clayton
run6.0run
May 27, 2014 09:02 PM
TireJockey
Jan 11, 2013 06:53 AM
dieselsubmariner
24
Dec 27, 2012 04:50 PM
catman52987
Jan 29, 2012 10:37 PM
canister
Feb 16, 2010 04:14 PM
