Just got a 1993 ford f150 4 wheel drive, The guy I got it off of said he replaced the fuel tank on the rear had a leak he replaced it with a used tank and new fuel pump now it will not run. he said it may be the lines not connected right, My question is art the lines different sizes and if he did not have them connected all the way wouldnt they leak I have the battery charger on it now. just wondering where to start, Thanks Raybob
The lines won't leak if the pump isn't working. Will it start on the front tank? Did you pull the codes? See if you have power from the selector switch to the rear tank, and check the relay.
Yes, the lines running to/from the fuel tank are different sizes. Pretty hard to screw up.....
If they did not get the lines all the way in to seat,, it should leak right. I am charging the battery now. found one other thing while I was looking under it the front spring shackel are rusted bad its 150 4 wheel drive just the front on the rear spring, thanks for the help. Raybob
always check, I pulled the rear tank off they said they replaced the fuel pump on 1993 f150. they did. but no o ring seal and locking ring broken. taken apart looks like a new pump, I found a small piece of rubber a little smaller than a dime and it has a small tit in the middle very thin. I dont know what this is. Thanks Raybob in ky
