This is prolly a 1 page thread at most
Received 4,141 Likes
on
The following users liked this post:
Truck is at the dealer, Took an hour for the courtesy driver to return to the dealership and give me a ride home.
I just pulled up the camera feeds on the new school. We have security cameras, that I can pull up on my cell phone or laptop. Snowing there and everybody has gone home. So I won't be missed. Turns out to be a good day to be truckless. At least I don't have to commute down to the school on the first snow day.
Freeway is a mess from the radio reports. Everybody forgot how to drive, or maybe, it's just all the Californians that moved in that never learned how to drive to snow. They had a report on the news that we are one fastest growing states in the US and most all the growth is Move in from outside the state.
Guess I'll take my shoes off and go take a nap.
The following 5 users liked this post by Painted Horse:
on
Lynn said from the beginning....... The only way out of this marriage is by death. You do have two choices...... By natural causes or by bullet holes. This was said as she was shooting a steel can, making it dance up a hill side....
on
Received 3,855 Likes
on
Good morning guys!
No snow here yet, 30° and clear this morning!
Nice picture Bill, thanks for sharing.
Don, Glad to hear they are making progress on your home.
I got the large farm gate all welded up and a little primer on the welds. It turned into a real task, the pipe in using to extend it is galvanized EMT. The gate itself is just as thin. So to start with a wear a chemical fume respirator under my welding helmet sense in welding galvanized. I have a pair of safety glasses that have bifolds on the top that normally work well for welding but the respirator kept pushing them to high and I couldn't see. I kept burning holes in the thin pipe. I switched over to Silicone Bronze welding rod and installed the little finger switch to run the TIG torch. Sense it's not structural I figured the Silicone Bronze would be ok. Took my glasses off move and moved a little closer, ok things are starting to come together. But then I tripped on the finger torch wire and pulled the torch off the gate and to the floor.
Nothing broken, ok good back up the ladder and start welding. One time it worked good then it would act up and the welder would go into an error code and lock up. After a little investigation I found that when I tripped on the control cable I pulled the insulation away from about an inch of the wires at the finger controll. After I repaired that all went well.
My mask, in hopes of protecting myself from the fumes of welding galvanized.
Once it's painted, I will install the same wire our fence is made out of.
A fineshed weld, sorry no pictures of the holes. LOL
The coping before welding.
We did manage to get our Christmas tree up a couple days ago also.
The following 12 users liked this post by Tim Young:
Received 6,993 Likes
on
Nice job, Tim. Man, if you were about 3000 miles closer I would pay you to make our chain link gates. I thought you were using 1-3/8" OD & 1-5/8" fence tubing. The notches are done right! We use a minimum of .055" wall tubing around here. .065" is better, but we are in a land of cheapskates.
Nice pic of you & Ms Tim. Looks plum festive!
The following 2 users liked this post by BowtieConvert:
Tim, I'm so illiterate about welding, I don't even know what I'm looking at to compliment you. But I assume you are making a tall gate to keep the freeloading deer out.
Dealer got my axle recall done. Only a couple hours and they called said come get it Snowing like crazy here, So underside of truck is coated with snow and dripping, So I'm not crawling under there to see what they did, Until it dries out. Couldn't even use my cruise control coming home. the little radar box was coated in ice and no signal.
The following 3 users liked this post by 4df150:
Received 5,314 Likes
on
