Fuel Filter Question
Old Aug 17, 2012 | 05:34 PM
John - Wenatchee's Avatar
John - Wenatchee
I was going to have my Fuel Filter changed along with my oil at the dealership, but they wanted almost $100 dollars to do it. The parts department wanted $40 for the filter. I saw at Riffraff the filter were only $18. The filter itself looks like it is really easy to do. Is there something additional that they are doing that I am unaware of? I feel that they have always treated me fairly before, but this seems crazy. Are there any words of wisdom to pass along? The Truck is 02 250.
Thanks!
John
Old Aug 17, 2012 | 05:53 PM
guitarpicr's Avatar
guitarpicr
Yea - I would tell them if they can do it for 50 - otherwise ,do it yourself- Takes about 5 minutes & this is something you have to do every 3 oil changes anyway. I would buy 3 or 4 filters & then you only pay to ship once.
Old Aug 17, 2012 | 06:02 PM
SpringerPop's Avatar
SpringerPop
They are bending you over a barrel, and about to stick it to your wallet!
This isn't rocket science, kids!
It's just changing a simple fuel filter that's up on top of the engine and completely accessible!
Pop
Old Aug 17, 2012 | 06:07 PM
JOHN2001's Avatar
JOHN2001
7.3L PSD - How To: Change Fuel Filter - YouTube
Watch this.......... and youll be wondering why you paid them to do it!
Old Aug 17, 2012 | 06:53 PM
WA_PSD's Avatar
WA_PSD
I'm about to do mine for the first time and wonder if I have a stock filter and lid or combo so I guess I need to check? If I order just the filter and have a combo aftermarket lid/screen, will I need a new stock type lid?
Old Aug 17, 2012 | 06:56 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Go look at what filter set up you have before you order the new one. I would go with an OEM with filter and lid. If you already have the OEM lid you will save some money and just buy the filter. If you need both the filter and the lid it will be a little more expensive but better in the long run. OEM filters are good quality, where as the aftermarket ones will span the whole spectrum.
Here are the part numbers for both, as well as a place to order them.
OEM Fuel Filter:
P/N: F81Z-9N184-AA
Riffraff Diesel: OEM Fuel Filter
OEM Fuel Filter Lid:
P/N: F81Z-9G270-BA
Riffraff Diesel: Ford Fuel Bowl Cap
Old Aug 17, 2012 | 07:04 PM
WA_PSD's Avatar
WA_PSD
OEM Fuel Filter:
P/N: F81Z-9N184-AA
P/N: F81Z-9G270-BA
OK cool, thanks for the quick response. I'll check it out and see if it's stock or not and order accordingly.
Old Aug 17, 2012 | 07:09 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I prefer the OEM style filter with the separate lid but I keep some Baldwin filters in stock as well. Our trucks work across three states so we never really know which filter type it might have. Sometimes we go to change filter element only to find that the lid is incorporated. In those cases we just put in a Baldwin and send it on it's way.
File Type: pdf
Old Aug 18, 2012 | 01:02 AM
SpringerPop
I still have my stock lid, it's behind the rear seat, but there have been nothing but Baldwins in mine for the last eight or nine years.
I have nothing against the Racors, but I use Baldwin for almost all my filter applications.
Even my wife's Honda Pilot.
Pop
Old Aug 18, 2012 | 01:51 AM
timmyboy76's Avatar
timmyboy76
100 buks aint all that bad, considering you dont have to dispose of the oil. Think about it, around50- 60 buks for oil, another 10 buks for oil filter, and last i recall, the fuel filter is at least 20-25 buks.
I wouldnt pay it, since i do my own oil/filter changes, but inna pinch or live in an HOA neighborhood, then itsnot a bad route.
Old Aug 18, 2012 | 05:17 AM
Supercab's Avatar
Supercab
Wink
Thanks!
John
IF the dealer wanted $100. for JUST the fuel filter replacement, run as fast as you can away from that place!!
Unless you are somehow handicapped you can change your own oil, filter and fuel filter-easy!
You'll have to get the fuel filter at a parts store, but you can get the MOTORCRAFT FL-1995 oil filter and Shell Rotella oil right at WalMart-I highly recommend the full synthetic 5w40 stuff-I have been running it for 4 years now in mine, always send in a sample to Blackstone and last sample was so good they recommended going to 12k miles next time!
Old Aug 18, 2012 | 07:55 AM
Franko72's Avatar
Franko72
Molon Labe
$100 isn't bad being that it may save you from being electrocuted.... Remember what the instructions said....------>https://www.ford-trucks.com/forums/1...-pathetic.html
Forgive me...
I run the same oil Rick, and change it out at 8k towing, & 10K not towing with a filter change @ 1/2 life. I need to get a sample off to Blackstone to see what they have to say.
Old Aug 18, 2012 | 08:08 AM
Tugly's Avatar
Tugly
PM sent! We'll be talking.
Old Aug 19, 2012 | 05:02 AM
Supercab's Avatar
Supercab
Wink
Forgive me...
Frank, By all means get an oil sample done by Blackstone.
I don't know that you need to replace your filter at the 1/2way point though-my last oil report with all kinds of towing including the run to pick up the trailer in Ohio was real good, they recommended going to 12k this time-I usually add 3-4 quarts between changes, sometimes less.
Old Aug 19, 2012 | 08:06 AM
dn29626's Avatar
dn29626
I use the Puralator fuel filter because it is (still) a USA product and Motorcraft oil filter.
