fuel leak under filter
Old Aug 16, 2012 | 08:31 PM
gbeach's Avatar
gbeach
Okay,
I have not posted in a long time, but I always go here before I start working.
1993 f250 7.3l idi. changed the fuel filter back in Oct. put a wix filter on. Noticed the truck smoking when I stopped today and fuel is leaking at the bottom where the plastic cap screws onto the filter. It is definitely not leaking at the top. I have not put a mirror underneath to see what is going on. But I can't remember if there is a oring on the bottom. I know there is one on the top. Leaking pretty good. any help appreciated.
Old Aug 16, 2012 | 09:58 PM
91dirtydiesel's Avatar
91dirtydiesel
pretty sure there is another o-ring between that plastic cap and the filter
Old Aug 16, 2012 | 10:13 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
there is an o-ring between the aluminum base and the filter, there is also a drain **** on the bottom of the filter base which could be open. both screw on, make sure they are both tight.
Old Aug 17, 2012 | 07:05 AM
gbeach's Avatar
gbeach
thanks, I forgot about the drain at the bottom. I remember the oring at the top. Is the drain at the bottom the round piece screwed on to the plastic piece. it is definitely not leaking from the top.
Old Aug 17, 2012 | 07:07 AM
gbeach's Avatar
gbeach
could not remember if there was a oring between the plastic cup and filter at the bottom.
Old Aug 17, 2012 | 01:47 PM
akamacgyver
Clueless spectator!
Yes there is an o-ring at the bottom of the filter. I have not seen one fail, but there is one there.
Old Aug 17, 2012 | 01:52 PM
gbeach's Avatar
gbeach
I have read on some other posts there is also a washer on the drain valve.
if it is the oring, where would I get that at. I will know more tonight.
Old Aug 17, 2012 | 07:43 PM
gbeach's Avatar
gbeach
okay, my leak is at my drain valve at the bottom of the filter. as tight as it will go and still leaks. I used a wix 33217 filter. It says I can use a wix filter to eliminate the spin on bowl which I think will save time and money instead of looking for a plastic spin on bowl. Do I use the wix 33417 or the wix 33617. the oring was leaking also, i greased it and the leak was then just out of the drain. but it makes no sense to have so many leak points.
RavageX
Dec 6, 2012 11:27 PM
crazymut
Jan 1, 2010 11:51 AM
7.3blacksmoke
Jul 20, 2007 12:12 AM
Lushman
Apr 9, 2006 01:44 PM
