1978 - 1996 Big Bronco
need some advice
Old Aug 17, 2012 | 03:15 PM
Raleigh1's Avatar
Raleigh1
It is a Pro-Jection system.
A speed density TBI, it works great, has a closed loop and is far more efficient than a carb.
I picked it up used for $250, best upgrade I have made so far!
Old Aug 17, 2012 | 05:53 PM
Geo6311's Avatar
Geo6311
Yes it is anyways I got the bronco putting out nice revs until I shift into drive or reverse then I get nothing the truck just wants to die
Old Aug 17, 2012 | 06:20 PM
Edgethis's Avatar
Edgethis
Have you checked for codes? Prolly the MLPS sensor, its not sensing coming into gear and bumping up the idle.
Old Aug 17, 2012 | 06:46 PM
Geo6311's Avatar
Geo6311
Thanks or the reply edgethis
I am getting code 98 from the truck while running and code 63 even tho I have replaced the tps and set it to 0.50 at idle and is climbs to 5.0 at wot just fine lol I am at a stump I will check the mlps and see if that's it thanks for all the help guys
Old Aug 18, 2012 | 11:36 AM
Geo6311's Avatar
Geo6311
thanks for all the help guys i put in a new tps and some other things new maf etc and she runs great thanks again
Old Aug 18, 2012 | 12:08 PM
Encho's Avatar
Encho
The Southernmost Mod
Please list all the parts, it will help others having the same issue.
Old Aug 19, 2012 | 03:34 PM
Geo6311's Avatar
Geo6311
I put in a new maf PCM and tps sensor now she runs great I also re checked the timing and every was ok after these changes the tps was no showing any sighs of or response but when I got the new one it was showing 1volt at idle this is good then 5volt at wot the maf and PCM I change just to make sure
highntight
Oct 17, 2013 09:49 AM
rsillmon
Mar 3, 2005 12:11 PM
bud driver
Jul 8, 2004 04:59 AM
nooner
Jan 26, 2004 07:51 PM
tacogrande9
Mar 21, 2003 07:38 PM
