Cant get into reverse
Old Aug 16, 2012 | 06:16 PM
eichenlaub's Avatar
eichenlaub
I have a 1983 f350 drw that will not go into reverse with the engine running. I have replaced the clutch with a new clutch kit and had the flywheel resurfaced. Before this it was hard getting into first alot of the time and now that is fixed but still no reverse. When I do try to shift into reverse I get alot of grinding and have to turn off the engine, shift and restart. Is the linkage bad? do I need a new flywheel or is something in the transmission itself going bad. Thanks
Old Aug 16, 2012 | 06:41 PM
IDIDieselJohn's Avatar
IDIDieselJohn
1983, I can't remember if the diesels used mechanical linkages or they went to Hydraulic.
If it's hydraulic, I bet'cha the firewall is cracked and it's flexing when you step on the clutch.
Heres what you need if you have that problem...
https://www.ford-trucks.com/forums/1...l#post11358654
Old Aug 16, 2012 | 08:09 PM
eichenlaub's Avatar
eichenlaub
It is hydraulic, I never would have thought of a problem with the firewall, thanks so much.
Old Aug 17, 2012 | 11:53 AM
Dieselamour's Avatar
Dieselamour
There is also some information on utube about the rod on the clutch master cyl. There may be a cheap plastic bushing at the rod's pivot point and the clutch lever. Apparently these fail quite often and can cause substantial wear which reduces the throw.
Your original statement on it not going into first before the clutch replacement but now not going into reverse after the clutch replacement shines different light on the subject. Did you loose any trans fluid (oil) when the clutch was changed?
I have found it common and generally acceptable practice to put the transmission in 2nd before first gear and 4th gear before going into reverse to stop the transmission from turning and prevent grinding. Every gear should have a synchronizer with the exception of reverse, maybe the synchronizer is worn or you have the wrong weight oil, or not enough oil; don't know. Hope my ramble helps you.
Old Aug 17, 2012 | 12:07 PM
fordguy7904's Avatar
fordguy7904
More than likely the sincro is out for reverse same thing happed to our shop truck. had new clutch and slave cylinder also but didn't have reverse after just getting truck all back together so trans had to come back out and get sincros fixed
Old Aug 17, 2012 | 02:05 PM
Rxracer27's Avatar
Rxracer27
Being an 83 that would be a T19 and to my knowledge i dont believe 1st or reverse is synchronized.
Rob
Old Aug 17, 2012 | 02:16 PM
fordguy7904
I thought you were talking about a zf5 whoops but your right t19 has no sincro for reverse but would the shift collar be worn out
Old Aug 17, 2012 | 03:03 PM
Rxracer27's Avatar
Rxracer27
ZF are notorious for reverse issues, my current ZF has a bad revers you have to roll forward and slip it in reverse while its still just creeping forward to get it to fully engage.
a bit off topic sorry lol
Rob
1972fordhighboy2
Dec 17, 2024 02:19 AM
mtsnieg
Nov 20, 2023 09:56 AM
AKHunter93
30
Nov 6, 2019 03:16 PM
91f2504x4
21
Jan 23, 2009 12:56 PM
mdjohnson
Nov 6, 2005 09:17 AM
