Smoke on hard acceleration
Old Aug 16, 2012 | 07:30 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
double post
Old Aug 16, 2012 | 09:29 PM
BeerCan500's Avatar
BeerCan500
Smoke Analysis
Smoke analysis
<DL><DT>White smoke: <DD>Caused by unburned fuel passing through the engine. Some white smoke is normal on cold start-ups.
Excessive white smoke could be an indication of inoperative glow plugs, loose injectors, low compression from worn rings or bent connecting rods, or coolant leak into the cylinders. <DT>Black smoke: <DD>Caused by excessive fuel for the amount of air drawn into the cylinders. Some black smoke on hard accel or at higher altitudes is normal.
Excessive black smoke could result from restricted intake or exhaust, inoperative leaking or weak turbo (if equiped), intake manifold gasket leaks (turbo), leaking or worn injectors, fuel return or supply restriction, advanced injecion pump timing or defective injection pump. <DT>Blue or blue/white smoke: <DD>Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods.
Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, thermostat stuck open, oil consumption, plugged crankcase depression regulator valve, retarded injection pump timing, or defective injection pump.</DD></DL>
Old Aug 16, 2012 | 10:06 PM
91dirtydiesel's Avatar
91dirtydiesel
Originally Posted by BeerCan500
Better talk to Dave Spaunagle....He's da man...
had to LOL at this
here is what the smoke looked like before my IP and injectors got replaced. it cleared it all up.....well except for some black smoke now
91 ford idi diesel straight pipe - YouTube
Old Aug 16, 2012 | 10:10 PM
Brian085's Avatar
Brian085
**** well I guess it's time for injectors and IP. Any certain brands to get/stay away from? Should I get the new ones tested before install to make sure they are not defective out of the box?
Old Aug 16, 2012 | 10:12 PM
91dirtydiesel
start cheap tho, fill fuel filter with ATF let sit in IP over night, advance timing a bit then try it...saved me some coin with the 93 (had same symptoms, but much more blue/white smoke while driving)
Old Aug 16, 2012 | 10:16 PM
Brian085's Avatar
Brian085
I'm still a little confused on the timing advancing. Losen the 3 bolts and turn a center bolt 1/16'' at a time? I wish I could find a good video on this. It seems I can only fine the fuel screw videos. Im sure if I could do that suspension lift kit and steering gear box by myself I should be able to do this >.>
Old Aug 16, 2012 | 10:19 PM
91dirtydiesel
3 9/16" nuts that hold IP on, loosen those (kinda a PITA with a regular wrench, but doable) then there should be a 3/4" tab on the IP that you can use a wrench to adjust it (advance towards passenger side) then tighten it back up. pretty easy
Old Aug 16, 2012 | 10:22 PM
Brian085's Avatar
Brian085
So the 3 nuts on the back that are out in the open to be loosened. Where is the tab on the IP and how much should be adjusted at a time?
Old Aug 16, 2012 | 10:27 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Yes to advance the timing you rotate the actual injector pump, just like you would a distributor on a gas engine. To passenger side is to advance. Go about a dimes width to start.
Old Aug 16, 2012 | 10:51 PM
Brian085's Avatar
Brian085
Do you pull the IP back once the nuts are loose or leave it in place and just turn a tad to the pass side?
Old Aug 16, 2012 | 11:58 PM
91dirtydiesel
just loosen them, dont remove them, leave it in place you can turn it where it sits
Old Aug 17, 2012 | 12:04 AM
lemonshindig's Avatar
lemonshindig
Don't worry about it, it's partially burnt fuel. Both of mine did that too. But both were cheap trucks and still plenty reliable.
Old Aug 17, 2012 | 10:51 AM
  #28
Brian085's Avatar
Brian085
I just don't want something to fail on me in the worse time. I noticed it has a faint amount of white while just idling. Very faint. The most noticeable is at start or on high acceleration.
jayzeller79
Sep 7, 2013 04:42 PM
1bigjoe
Apr 2, 2010 01:01 PM
skychaney
General Diesel Discussion
28
Jan 10, 2008 07:25 PM
petepetersen
13
Sep 18, 2006 06:09 PM
Mkey
Jul 8, 2003 09:54 AM
