So do all Diesels smoke??
Old Jun 24, 2003 | 05:04 PM
Mkey's Avatar
Mkey
Joe has been very helpful with my questions....But I still don't understand how much smoke i should see coming out my exhaust? . I'm a girl and new to diesels..the truck runs great!! but smokes some under moderate acceleration...It is like it loads up and then blows out...Is it sometimes a fuel issue..IE contaminated??? Michelle..AKA Mikey/mike
Old Jun 24, 2003 | 09:31 PM
cartwright's Avatar
cartwright
I dont know about the 6.0, but most all diesels smoke some under acceleration. It is usually caused by over fueling, lack of air, or a cold engine.
Old Jun 25, 2003 | 10:12 AM
RUFUS79's Avatar
RUFUS79
That is very true. On my buddys dodge we went out and pulled the fuel pump apart and turned the fuel way up and put an aftermarket air filter on there and from a dead stop at a light or something the car behind us has to wait for the cloud of smoke to clear before they can drive. It doesn't mean that it is running rich or lean it just needs more air to help burn it. Mods to you turbo can help but even to this day I have not seen a diesel motor not smoke. Even my diesel generator smokes pretty bad. Black smoke means over fueling or not enough air and blue smoke means it could be worn out or its cold(warm up)
Old Jun 25, 2003 | 02:22 PM
Chronos_Titan's Avatar
Chronos_Titan
No not every diesel smokes, I have seen, many many diesels that do not smoke. It was fairly rare for a 7.3L powerstroke to smoke, mostly the only ones that did it were in need of maintence or had been modded.
Any diesel that has been made in the past ten years should not smoke at all. Just look at the newer Volkswagen Jettas. If it says TDI on the back right hand side, where the engine badge goes, it is a diesel and i have never seen one of those engines smoke.
I hate to tell you but if everything is perfect on your new 6.0 then it should not smoke, no matter how hard you accel. This is a requirement to pass emissions. So your truck has to have something wrong with it, weather or not it could affect anything is hard to say.
Monitor your oil level and your fuel milage, if your oil level goes up you have lost an injector. This is the most likely cause and something that your Ford dealer should be able to fix relatively easily once they find the right one.
Old Jun 26, 2003 | 09:32 AM
Guero's Avatar
Guero
I have a 7.3 and a 6.0. My '95 7.3 has always smoked some as have all of the ones I have been around or driven. It is not bad unless it is a cold day or maybe going uphill loaded. I have never had any problems with my 7.3 and it now has 153k on it (still smokin') My 6.0 was smoking some on take off loaded but the reflash seemed to stop it. I notice a little puff occasionally, I live and work and play in Eastern New Mexico and West Texas, I have been around diesels all of my life and seems to me that they all smoke some. I'm not a mechanic and I'm not arguing with anyone, just stating my observances........
Old Jul 3, 2003 | 03:07 PM
Kelton Trent's Avatar
Kelton Trent
Kelton trent when i start mine first thing in the morning it smoke for a few secondsthen it clears up .
Old Jul 6, 2003 | 12:39 AM
dman01's Avatar
dman01
most new stock diesels don't smoke but when they get a few 100k miles on them they start to smoke. as things get warn out or if the truck it missused then they start to smoke. my 98 24 dodge smokes a little bit but its nothing to smile about. my 93 with 103k on it never smoked until I learned a few things about the pump My buddys 7.3 always smoked since the day he bought it. a little more than my 98 24v but nothing that would make a car stop and wait that is until we learned a few things about the pump
If it aint smokein it must be broken
Old Jul 6, 2003 | 02:54 PM
1975 f150 360's Avatar
1975 f150 360
my dad has a 84 f250 6,0 liter diesel and it has about 100,000 on an overhaul and it smoke on hard excelleration and thats it, i have a fried that owns a 2002 f250 7.3 lier diesel and it smokes a lil bit and hard excelleration pulling a trailer, and theres a 1995 dodge 2500 cummins diesel thats had the pump messed with and a lot of mods to it and it smokes a little pulling a trailer, when a diesel smokes it doesnt mean its worn out or somethinf wrong with it, if thats the case just about every doesel has something wrong with it but they seem to all run fine the ones that smoke that is
1975 f150 360 2x4
Old Jul 6, 2003 | 11:28 PM
The Diesel Dude's Avatar
The Diesel Dude
Your dad's engine is a 6.9L engine.
Old Jul 7, 2003 | 12:08 PM
1975 f150 360
yea sorry i meant to hit a 9 instead of 0
Old Jul 7, 2003 | 11:47 PM
gjhack's Avatar
gjhack
Wow, tough crowd.
Old Jul 8, 2003 | 09:54 AM
Chronos_Titan
A new 6.0 should smoke very lightly on a full throttle accel up through the rev range. It should never have visible smoke no matter what throttle position when it is held at a steady state. The emissions levels for the truck allow it to smoke lighly on hard accels, so i wouldnt think this to be unusual. Of course once you change over programs or mess with something in the truck it will smoke like a freight train.
ms_michelle
401, 477, & 534 SD Engines
52
Jul 15, 2025 10:59 PM
ms_michelle
20
Mar 7, 2022 12:09 AM
Mil1ion
New Member Introductions
Dec 30, 2004 02:39 AM
ms_michelle
1978 - 1996 Big Bronco
Sep 16, 2004 01:10 AM
Michelle_Andree
May 1, 2004 09:14 AM
