Bed Liner and bondo
Old May 13, 2003 | 10:20 AM
stemen_a's Avatar
stemen_a
Bed Liner and bondo
I was thinkin of putting a do it yourself bedliner on my whole truck. it's just an old farm truck thats starting to rust out. I was wondering what some of the best kinds cheapest for the best quality and where you can get them. also another question. I'm terrible at body work and anything I bondo eventually cracks and looks like *****. anyways I was wondering if I used bondo on some dents in the truck and then rhino lined it or w/e. would the liner be tuff enough to keep the bondo from cracking it? whats your opinion?
Old May 15, 2003 | 11:20 PM
Colossus's Avatar
Colossus
Bed Liner and bondo
Well...I did this same thing last summer to my dad's '78 F250. If you are going to use a kit, they are expensive (around $90) and they are tricky to use. You must follow the instructions to the letter in order for it to cure properly. I used Herculiner over Bondo with no problems, now if your Bondo cracks, well, I would say get some practice or something. It was the first time I ever used bondo and I never experienced cracking. The liquid bedliners do not stick to rust either. Now, you said you wanted to apply it to the whole truck? Well, thats a bit much ($$$).
Every bit of rust had to be sanded or drilled out and then primed with SEVERAL coats of primer, at least thats how I did it. I had a little peal off though. I will add, if I had to do it again, I would have a professional do it. I put a lot of time into that truck, I stripped the whole bed down to bare steel and used Herculiner.
Good luck.
oldwi
Sep 2, 2013 02:37 PM
das54
Jun 15, 2013 12:31 PM
56efffie
22
Mar 15, 2007 11:26 AM
aksniper
Aftermarket Products
Mar 3, 2006 07:00 PM
pntrbl
Paint & Bodywork
Mar 24, 2004 07:40 AM
