Sponsored by: Real Truck
Small door will not open
Old Aug 16, 2012 | 11:25 AM
Gary E K's Avatar
Gary E K
I think the cable that goes to the top latgh is broken, how do I get to it to fix it?
Old Aug 16, 2012 | 12:40 PM
jones20992's Avatar
jones20992
Some times mine does this and the only way I can get it to open is to pull the handle and at the same time push on the out side of the door then pull on the door to open it. To get to the top latch assembly iirc you have to pull the door panel off there is 2 screws one behind the lamp lense and one by the handle you have to take loose the vent window latch then with the palm of one hand hit up in the bottom of the top of the window frame and at the same time pull up on the bottom of the door panel. Mine I had to get a little western with it but was still careful not to be to rough as not to damage the door panel
kgross
Apr 14, 2016 08:21 AM
john jamieson
Apr 1, 2016 05:57 PM
StealthWyvern
Nov 21, 2014 07:16 PM
B Big
19
Nov 9, 2010 11:15 AM
Gary (UT)
1978 - 1996 Big Bronco
Dec 21, 2004 09:38 PM
