Drivers' inside door handle broke
Old Oct 21, 2010 | 11:08 AM
B Big's Avatar
B Big
Well the drivers side door has been hanging up when I try to open the door. Someone said Ford used small bushings(?) & they wear out. Now the handle has completely broken off (inside). I have to roll the window down & use the outside handle to open the drivers door- PITA!
Anyone have experience with this?
Thanks!
Old Oct 21, 2010 | 12:15 PM
bad12jr's Avatar
bad12jr
Mines like that at the moment. Havent had time to fix it yet.
Old Oct 21, 2010 | 12:36 PM
superduty4x4's Avatar
superduty4x4
The cable stretches and isn't able to pop the latch anymore. I had this problem on my 92 F250 but I can't remember how I fixed it for the life of me. That was back before the days of internet forums
Old Oct 21, 2010 | 12:40 PM
rolsmojave3's Avatar
rolsmojave3
When I bought my truck it had a broken handle...I replaced it, still a pain to open. Took off the door panel to find around the handle mount had cracked out of the door frame. I used large washers to reassemble it, It's been fine ever since. Lube it up good if you take the panel off.
Old Oct 21, 2010 | 12:49 PM
bad12jr's Avatar
bad12jr
That's what I gotta fix on mine. How do u remove the hand crank on these. My other truck had electric windows. Sorry to hi jack but I need to fix mine too.
Old Oct 21, 2010 | 05:11 PM
superduty4x4
Hand crank is held on with a clip between the crank and door panel- reach between there with a screwdriver and pop the clip off then the crank will slide off.
Old Oct 21, 2010 | 10:59 PM
JTyler11688's Avatar
JTyler11688
Mine tore the sheet metal where the door handle was bolted to the door frame. I bought a huge fender washer and re bolted through that, and that thing is as solid as any door handle I've felt!
On my window crank, you pull the plastic cover back and there's a torx screw holding it on.
Old Oct 21, 2010 | 11:14 PM
bad12jr's Avatar
bad12jr
Ok I'll check it out tomorrow. My S10 i had had a clip but wasnt sure what these trucks had.
Old Oct 21, 2010 | 11:45 PM
KonaGrown's Avatar
KonaGrown
Mine kept breaking too. I was too lazy to fix the door when it happened, so I just purchased a chrome metal one at Napa. hasn't broke yet
Old Oct 21, 2010 | 11:51 PM
chicagodragon's Avatar
chicagodragon
i think on the handle... the outside trim snaps off, then there is a torks type screw.
Old Oct 25, 2010 | 10:03 AM
superduty4x4
You guys are correct, I was thinking of a different vehicle.
Old Oct 25, 2010 | 11:25 AM
chicagodragon
i didnt even see he posted that before me.
Old Oct 25, 2010 | 12:13 PM
MustangMatt96GT's Avatar
MustangMatt96GT
Can also twist the cable a few rotations to "shorten " it and it will last a little longer... replacing that cable is a PITA
Old Nov 8, 2010 | 03:44 PM
bass-n-fire's Avatar
bass-n-fire
This exactly what happened to mine and I used the same fix. Still works after 2 years.
Old Nov 8, 2010 | 03:58 PM
bad12jr's Avatar
bad12jr
Well still havent had time to fix it.
Btw bass-n-fire that truck is BEAUTIFUL
