p0299
Old Aug 15, 2012 | 04:47 PM
ksunderwood's Avatar
ksunderwood
p0299
I have a 06 f250 6.0 liter with 118,000 and stock with an edge evolution only used for the guages and an afe filter. I was towing a boat thru the desert with mild grades when my engine light came on. I checked dts and it said p0299 ts/ underboost. The truck ran fine but it would have a high turbo whine. I reset it and it did it again about 150 miles. When I am not towing it is fine any suggestions?
<!-- / message -->
Old Aug 15, 2012 | 06:50 PM
redford's Avatar
redford
FTE Leadership Emeritus
Try this:
P0299 lack of power and turbo sticking on a 6.0 Powerstroke F250 diesel - YouTube
Old Aug 15, 2012 | 11:47 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Aug 16, 2012 | 09:28 AM
ksunderwood
Yeah I was afraid of that, also wondering if there is anything I should try before having turbo cleaned thanks for response
Old Aug 16, 2012 | 09:34 AM
atomicglock's Avatar
atomicglock
Most everyone on here will tell you the turbo is corroded and/or carboned up and needs cleaning. I had a similar problem but it turned out the pin that engages the slot in the unison ring wore a small notch in the ring causing it to hang up just long enough to throw a code. Just something else to check.
Old Aug 16, 2012 | 09:42 AM
ksunderwood
How easy is it to do your self?
Old Aug 16, 2012 | 11:11 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If you've never taken the turbo out, that alone can be anywhere from a 15 minute to multiple hour ordeal. Once it's out, it's a fairly involved 10-page process, but if you take your time there's nothing horribly difficult about it.
If your Private Messages work, send me one with your email and I'll send you some turbocharger info that's floating around on the forums about how to do this.
Old Aug 16, 2012 | 12:42 PM
ksunderwood
Will do thanks
kenny knight
Sep 1, 2012 10:17 PM
xluckyxbulletsx
Jun 25, 2009 10:10 PM
67nukeford
Mar 4, 2009 01:39 PM
jetch114
Aug 10, 2007 12:30 AM
GR8TWHITE
Apr 18, 2007 10:09 AM
